F5 amp for three way active speakers
Any form of time alignment is valid only on one exact point in a 3D space with real drivers mounted vertically on a flat baffle, you can choose which. Not always for the tweeter axis as some may be better few degrees off-axis. And obviously once you have drivers with vertical distance between them, the distance from the array means your relative distance from each driver changes and defeats any attempt at time alignment.
Concave line array and coaxial driver seem to be two possibilities to combat this problem (apart from 'fullrange' drivers), if in fact it is a problem. In my experience this is mostly true for midfield distances, in larger spaces the environment has a significant influence on time domain performance. In the nearfield (assuming a small array) there are very few room effects and you mostly are listening to a point source.
Anyway your question was about the F5 and an active 3-way. I built my own 3-ways with Volt B2549, and Satori 5" woofer and the Satori Neo tweeter. We specifically chose a fully passive setup with the top portion of the baffle tilted back (the low crossover is so low that time alignment is not a problem, but this M/T combo does not behave properly on a flat baffle anyway). System nominal impedance is 6 ohm with a low of 4 ohm, sensitivity is 88dB/w, and a two-pair F5 Turbo drives it beautifully and it goes significantly louder than my threshold of hearing will allow. It also has in-room response down to 18Hz and the large driver handles bass like a beast. The F5 is really a great match.
The output devices in the F5 do not sound nice when used at low levels of bias. If you are using low-power F5s, keep the supply voltage as low as possible, so you can run the bias currents high. A baseline is 1.1-1.3A for a single pair or at least 700-800mA/pr for 2 pair output - less than that the sound tends to get muddy. I use 3pr outputs very often and the amps like to run around 2-2.1A bias for a great sound. Similarly, I like to use about 10VA/w of power output, so a 600VA transformer would be typically used for 30W/ch amp.
Basically don't assume you can use same transformer if you need to run lower and higher power amps off the same power supply, or you should plan to use cap multipliers to drop the voltage to the amp for the top/mid. And another note on the active crossover. If you don't follow the exact discipline that Patrick's pdf showed you will never be able to arrive at the correct crossover topology. The only bonus is that you don't have to deal with driver impedance in active setups, but that doesn't mean you can plonk in any slope and frequency you like.
While doing this exercise we inferred that sometimes, a passive setup can outperform an active setup if it is properly done, the only caveat being the unavoidable drop in sensitivity. Good driver pairings have symbiotic rolloff and impedance characteristics, and very good drivers tend to have excellent correlation between data and retail product. This makes them simple to work with. Don't forget that though you will gain back the insertion loss from the woofer inductor, you still have to plan for 2.5-4dB of baffle step compensation. You might know this already, but just putting it out there.
Hello, plasnu.
I will check your link a little bit later, thanks.
I understand about class D and also consodered class AB for woofers.
But accordong to the box calculation, my preselected woofer in sealed box will reach its Xmax at 21W average power govig 103dB as I remember.
Seems, it does not require class D here at all.
Or I have to replace woofer...?
Room is 28 sq. meters - if it is really not enough?
BTW, I thought about Aleph J but it is single ended, while my mid and twitter are 4 ohm. I need to estimate if there is enough capacity.
Anton
Hello, plasnu.
Anton
Hi Anton, What I wanted to say is not to forget having 6 channel Class A amps may dissipate crazy amount of heat even when no sound is coming from your speakers. 😀
BTW, my Class-D is Icepower 50, rated 50W. 🙂
I used BASTA! software for preliminary power calculation.
If start from woofer with its Xmax at 21W and 103 dB this means 2.3A of class A into 8 ohm coil.
Just fine for F5 with it's 2.6A push pull stage.
Assuming baffle step, to reach same 103dB the mid driver will require 16W only.
So, it will need 2 A in class A into its 4 ohm coil.
F5 is also OK here, right?
Seems, twitter will require 8-10 W only.
I see, Plasnu. Will check Icepower too.
Does it mean that Aleph J dissipates more than F5?
100W against 64W?
Oh, I was not recommending particular class D, but Icepower is not a bad choice if you can get it cheaply on Ebay. I paid @$60 par stereo board, and it includes PSU.
I think regular Aleph J dissipate a bit more than regular F5, but not much difference, right?
AntonTR, I'm not trying to confuse you, sorry, but dissipation was what I had not seriously considered before building this 6x AJ, so I just wanted to tell you that.
While I'm 120% happy with the sound of this amp, but due to heat in my room, I'm planning to make another 6 channel class-A amp, it probably will be choke loaded single ended like Mofo or L'amp. 1/2 dissipation of AJ.
I think that single ended will dissipate too much if i need 2amp at least for 4 ohm mid.
Other way is to reduce PSU voltage for mid and high as soon i dont need so much power according to my calculations above.
This should also reduce dissipation in theory.
It is none of my business what you, AntonTR, are going to build, but making 3 stereo classA amps for 3 way speakers is a total waste. ClassA is great for tweeters and mids, but for woofers its a waste, any class AB or class D amp is just fine. I would even use passive between tweeter and mid and use only one classA amp. But that's just me, I am lazy by nature. Well, not exactly, I have about dozen amplifiers to swap and compare the sound. What I do is active crossover at ~150Hz, then have woofers powered by the same classAB amp, and then keep swapping only stereo classA amps for mids and tweeters. That's enough excitement for me. Cheers!
(I have not read all thread)
Reactions: Gill.T
Thank you for you opinion, Mr. Adason!
Seems, this approach is like a golden balance between efforts and result.
Some people have already offered this arrangement.
I think it worth to consider.
So, your crossover has a two way filters sections:
20-150 Hz for woofer and 150Hz high pass for mid and twitter, right? Then you use passives between mid and high driver as usual, correct?
What is the filters order?
Class-D just for woofers seems to be a good idea, and seems to be logically correct, but I "personally" prefer that all the drivers are driven by the same amps. When different amps are used at the same time, I feel like comparing amps, and I can't stop ignoring the drawbacks of each amps. In my ears, amps are fighting. I know I should appreciate the strength of each amp, but I'm not that smart enough. Funny. 🙂
Well, there are other benefits, like if your woofers are lower efficiency, you do not need to kill power to midrange and tweeter with resistors, you just adjust level.
Or if your woofer amp is clipping, it does not polute mid and tweeter with upper harmonics of distortion.
Or you want to save on expensive duelund caps or foil inductors.
Or you built too many amps.
