dwRK said:I have a transformer with 2x 0-30V secondaries, rated at 530VA.
Rework the transformer to 4 x 15Vac secondaries.
Or design a choke-input-Filter, that will bring you down to 23-24 V. But it is easy to buy new transformers I guess.
now that I have all the parts for a F4, I'm wondering if it's the best amp to build ... I'm working a pair of speakers that are shaping up to have the following specs:
about 3dB of BSC
-3dB response at 39 Hz
the woofer is ~86dB efficiency
sum is around 83dB/W/m
I haven't decided really on a proper preamp to drive the F4, so that could definitely be a factor in the equation.
Any opinions?
about 3dB of BSC
Any opinions?
Which F4 configuration are you planning on? If you are doing a simple 2 channel single ended amp, I would say you won't have enough power. If you are going to go balanced or bridged, then I think you should be ok.
Babowana said:F3 . . . ? Not F4 . . . ?
I am confused too;
PD's board is NOT a F3! Its a ZenV9
DaveM said:Which F4 configuration are you planning on? If you are doing a simple 2 channel single ended amp, I would say you won't have enough power. If you are going to go balanced or bridged, then I think you should be ok.
sorry, dual mono with a pair of donuts and (4) F4 boards
luvdunhill said:now that I have all the parts for a F4, I'm wondering if it's the best amp to build ... I'm working a pair of speakers that are shaping up to have the following specs:
about 3dB of BSC
Any opinions?
Yep, you need a Pumpkin, and everything will be fine....
Hey... Steenoe... I really hate myself, for discussing with the "big guys" in here 😉 ... But, if you don't have sources, with a lot of output, it dosen't do you any good (except soundquality ofcause).
What i mean, is that the Pumpkin is capable of swinging nearly 70Vac, but with a source giving perhaps 1,5Vac out, you still only will get around ~15V out (I think F4 need 25V to drive them max???)
Pumpkin or not, you really need some gain to drive speaker's around 83-86dB (Trust me i have been there with 87dB one's). Actually my Pumpkin with 2pcs. F4 full balanced monoblock's ain't capable of driving them anywear near limit.
I have just build, a pair of halfchang, with fostex fe207e (95dB), and with them the f4's really begin's to rock😀 ... But but still the volumeknob must be around 12-13 oclock.
Jesper.
Jesper.
just pump the gain of Pumpie
15x (23,5db) is completely same as 10x , for Pumpie ......... but not for F4
besides the Xono, which has lots of voltage, my digital source is rather wimpy.. it's 1.99V for both balanced and unbalanced outputs.
You can adjust the Pumpkin's gain as you please🙂 Just study the Pumpkin CookBook carefully, or ask Mr. ZM directly. I beleive that 24dB gain is within reason? Furthermore, dont use lower railvoltages if you want to drive it to the max. (low input and low efficiency speakers)
BTW, The CookBook is a piece of art!
Jesper.
Ya cant mean me, for sure. All I can do is put the things together😉
crazy danske guys ...........
Lucky - don't forget that Lykkkkk guy is the one who tried Pumpie with Leach, set on 1x10^9 db gain ...............
steenoe said:......
BTW, The CookBook is a piece of ******
hehehe
I'm here to please ya ..........
Jesper.
Lykke, I think I need some help with setting up my browser, I can't make it load the pics you posted of your new speakers.....Something wrong with the character encoding as well.....the review seems to not load as well 😡
Magura 🙂
Zen Mod said:
hehehe
Ya put in all the *****'s I didnt 😀
I am sure that Jesper has a point of some sort! I know him.....
Magura 🙂
maybe because he didn't upload any pics ?
Oh, you think it's an error code 40 ? 😕
Magura 🙂
Magura 🙂
is it here or on Lyyyyyykkkkkkkkkk's web ?
I guess the error code 40 is on Lykke himself 😀
Magura 🙂
- F4 power amplifier
