I have done that in a few different pass style amps, and it works just fine. Just pay attention to the spark suppression of the switch/relay.
Magura 🙂
Magura 🙂
I don't think the F4 will be perfect for low bias since the strength is more in the bottom end than the top end, and you'll not be able to drive the bass without distortion at a lower bias current. I ran my F4 at 80mA per transistor in the beginning and the bass was quite distorted.
A switch to change the bias is however very easy in this configuration and I don't think you even have to fear sparks, since you'll only need to switch the low current running through P1.
I have never done this with a F4, but in other circuits the sparks of the switches makes some rather nasty clicks in the speakers.
Magura 🙂
Magura 🙂
carpenter said:Thank-you! I've never looked for this feature in a switch. One more thing to know...🙂
that's reason why - when using relays for input selector or attenuator , is nice to have little elcos in parallel with each coil ;
OTOTOTOTOTOTOT
you could also probably have a switch inside the box of the pumpkin to set gain from high to low? I mean not for background listening, but to make it work with other amps..
Variac said:OTOTOTOTOTOTOT
if I understood correctly that OTOTOTOTOTOT was for me 😉
yup ;
relay/switch with two sections per channel- half ; one section for resistor side , one for lag cap side
so - two takamisawa double relays per channel ..........
naah - just play with input resistance ; that will be good enough .......
...... in that case one little takamisawa will be 'nuff for entire channel
Nah, the OTOT was for me because I was talking about the Pumpkin, but just a joke ,as how can you talk about the F4 without talking about
Pumpky every now and again...
So you are saying it's just as good to have a resistor you can switch in and out to increase the volume control resistance? Actually I was considering this to create more of a "two level" volume control to get more settings on the switched vol control, but there is always that risk that you have the resisistor switched in, then you increase the volume, then your little punk nephew runs over and magically decides to flip THAT switch...
(that's why I said "INSIDE the case.. ) ..
Variac said:Nah, the OTOT was for me because I was talking about the Pumpkin, but just a joke ,as how can you talk about the F4 without talking about
So you are saying it's just as good to have a resistor you can switch in and out to increase the volume control resistance? Actually I was considering this to create more of a "two level" volume control to get more settings on the switched vol control, but there is always that risk that you have the resisistor switched in, then you increase the volume, then your little punk nephew runs over and magically decides to flip THAT switch...(that's why I said "INSIDE the case.. ) ..
I agree with every word ( can I say or do anything else , considering that I write these words to who else than
say - R1 is made of one fixed resistor , and other one which can be switched in parallel .
same as R3
so - there is nothing with pot , just varying NFB
Variac said:Hey that was what I was trying to say at first
Bad Choky you stole my only idea...😉
so - 3 or 5 days in Sinnnn Binnnnn?
Variac said:Bad Choky you stole my only idea...😉
I've got some spares - I'll send you one.
Nelson was mentioned once as the kind of guy that has a small idea every 20 minutes and a big one every few hours!!
( I may have butcherd the quote, but close)
Nelson Pass said:Use a make-before-break, and it should be very quiet.
Think rotary switch, as in Grayhill.
Magura 🙂
Magura 🙂
Hey, thanks for the tip and the product name!🙂
That's how it works, having your personal nanny 😀
Magura 🙂
- F4 power amplifier
