Peter Daniel said:It's still OK.
Money sent for an extra F3 PS board.
Thanks Peter.
Just added to Wiki 3 PSU, 1 F3 and 1F4. The 3 PSU is one for F3 and two for F4. Is that $75 all together?
Yes, it is correct. Payment info was posted here: http://www.diyaudio.com/forums/showthread.php?postid=1680605#post1680605
Re: Balanced F4
what are benefits of connection from post # 33 compared to dual channel stereo
why not connect single PS pcb with single pair pcb instead of connecting both + and - to different pair pcbs
and some more psu boards
Peter - I will need 2 more psu boards - this time for the F2 - I assume that the F3 psu board will be applicable - if so thats another $30 to be paid.
Alan
Alan
Re: Re: Balanced F4
Got it thanks.
Refering to this diagram: http://www.diyaudio.com/forums/attachment.php?s=&postid=1672598&stamp=1228160049 it is bridged configuration with two amp boards per channel providing more power as described here (page 7): http://www.firstwatt.com/downloads/f4_om.pdf
Each PS board in that diagram represent single voltage supply (+ or - ), so for symmetrical supply required by F4 amp you need two of those, connected to each amp board.
You can also use 4 of those PS boards (it's a PS board broken in half at scoring line), 2 per each amp board.
Got it thanks.
samoloko said:what are benefits of connection from post # 33 compared to dual channel stereo
thx for explanation
could be achieved more power than 25 W from F5 connecting the upper way
if It can be done - are this going to be up to 100 W - has anybody test It
Is It correct that that way I need 2 F5 pcbs and 2 PS pcbs
In that way may I buy 5 PSU pcbs and 2 F5 pcbs from you
If so I have to pay you 7 x 15 USD and add 7 USD eventually for Insurance
Yes no problem, payment info here: http://www.diyaudio.com/forums/showthread.php?postid=1684087#post1684087
I just realised there are a few more adjustment pots on the F3 compared to the ZV9.
Does anyone have the instructions for setting up the F3 correctly?
- Group Buys
- F3 and F4 Clone PCB Reissue group buy, also F5 PCBs
