Re: PSU PCB
So if you making one amplifier with two power supplies in it, one for each channel, then having four 10,000 per side is good.
You could use less resistors on Peter PSU boards, for instance one 12w or higher .1 ohm or 2 10w .22 ohm per CRC path.
Pocoyo said:Thanks for the information Peter
As i have now
14 pcs elna for audio 10.000uf 63v
very big hope i can use it to power F5
is that ok if i use 2 psu pcb for stereo
2 pcb x 2 psu x 20.000uf for stereo ?
oh yes what for 4 x 0.47 r in that psu ?
Dear Peter,
I would appreciate to get some boards as well, do you still have them available ?
1 board F3 + 1 PS
1 board F4 + 2 PS
Thanks, Regards, Raoul
1 board F3 + 1 PS
1 board F4 + 2 PS
Resistors
Peter, anyone for the F5,
Are the series resistors - SWAG here -
R9,R10 R13,14?
Mike
Peter Daniel said:I based my choices for F3 on what I learned with GC and the results were pretty satisfactory, in fact F3 is still my reference amp for mids and highs.
So Mills would be for power, Caddocks for input shunt and feedback, and Vishays S102 for series resistors.
R9,R10 R13,14?
Mike
R9, R13, R14 are series resistors and I would be choosing Vishays here (if funds allow 😉); R10 is input shunt and Caddock MK132 worked best for me in this position.
aft said:I would appreciate to get some boards as well, do you still have
Yes, it wouldn't be a problem.
vishay s102 or VSH
Hi Peter
I noticed that the S102 resistors ($11.95) are about 2-3X the price of the the VSH bulk foil resistors at Percy and double the price of the Vishay VTAs at partsconnexion. Have you compared these 3 bulk foil resistors? If so which ones do you recommend. Also, partsconnexion now have takman carbon resistors. Have you tried these for series resistors?
JimS
Hi Peter
JimS
Re: vishay s102 or VSH
Jim,
I got a qoute from Texas components that make these resistors. (pretty sure)
I looked for qoutes on the 'nude' resistors for 1k R9, and 47 ohm gates.
Here is what I got. One reflects a single buy. A group buy doesn't help much. If we can get Mike Percy to do a large group buy of these, it looks like it would save a lot.
From Texas instruments.
Hello Mike,
Your quote is as follows:
[4] TX2352 1K0000 1.0% $6.95ea
[8] TX2352 47R000 1.0% $6.95ea
[100] TX2352 1K0000 1.0% $6.21ea
[200] TX2352 47R000 1.0% $6.21ea
Parts ship 2 weeks after order placement.
jims said:Hi Peter
JimS
Jim,
Hello Mike,
Great find, thanks! I am surprised that they only give about 10% discount for larger quantities. I was looking at the specs for their resistors and the TX2575 are also listed as "naked" bulf metal foil resistors. TC's look better. Did you happen to ask for a quote for these? Has anyone tried these?
JimS
JimS
jims said:Great find, thanks! I am surprised that they only give about 10% discount for larger quantities. I was looking at the specs for their resistors and the TX2575 are also listed as "naked" bulf metal foil resistors. TC's look better. Did you happen to ask for a quote for these? Has anyone tried these?
JimS
I asked about the 2575's, called em on the tele.
$9.40each <100
>100 8.39each.
I did find this thread regarding the texas components resistors.
http://forum.audiogon.com/cgi-bin/fr.pl?htech&1218474065&openfrom&10&4
Maybe being from texas, you could get a bigger discount??
I think asking Mike Percy about those 3.95 vishays is worth it, although I am not sure it's the same animal. 😕
Peter,
As usual I am late getting in to these group buys - what I was after were the PSU boards - I have just signed up for 4 F1 boards so would I need to order 4 of the psu boards or 2? And more importantly are they still available - if so I will add my request to the Wiki.
Alan
Alan
I always order more boards, so they are still available, ETA not known yet though.
We are past the WIKI sign up phase now, so if you don't want to miss those boards, consider making payment early.
PS boards compatibility info was posted here: http://www.diyaudio.com/forums/showthread.php?postid=1693713#post1693713
I tried those resistors, but was rather disappointed; I would not use them again.
jims said:Vishay VTAs at partsconnexion.
Re: Re: vishay s102 or VSH
That is not correct. On many occasions I noticed actually degradation comparing to regular resistors. Exotic resistors, or other parts, should be used carefully and chosen specifically for a particular location in a circuit. Not everything works well, and quite often, it is not an improvement but only a different flavour of questionable merit. Please see below my Ono boards: p2p with silver wire, packed with exotic resistors (even trimpots are Vishays) and yet, I didn't really like the results much 😉
from Audiogon
You are correct! A transparent, non-inductive resistor like the Bulk Foil Vishays(or Caddock Ultra- Precision Film) will make an audible improvement vitually anywhere it's installed in the signal path.
"TX2575 are also listed as "naked" bulf metal foil resistors. TC's look better. Did you happen to ask for a quote for these? Has anyone tried these?"
I am putting these TX2575 resistors in my JLH amp.
I can't comment on how they sound yet though.
Peter Daniel said:Thanks everybody for making it possible😉
http://www.diyaudio.com/forums/showthread.php?postid=1699240#post1699240
F1 and F2
For those of you hankering for building all The F-Series Pass amps,
Remeber there are ongoing Wiki's for F1's - due for production, and one for showing interest in the F2.
There are seperate Wikis for showing Interest in an F1 and F2.
F1
http://www.diyaudio.com/wiki/index.php?page=F1
F2
http://www.diyaudio.com/wiki/index.php?page=F2
F1's are being done and are a different footprint than Peter's board from dw8083
Happy new year everyone!
F1
F2
I'm receiving emails from people if they missed that group buy.
In fact I didn't close it yet and I didn't receive the boards yet, although I already got confirmation that F3/F4 and PS boards are fabricated, but I will probably wait for them to be shipped together with F5.
So if you are still interested in those boards, especially F5 as I ordered way more that interest showed, contact me for payment info or just go with the ordering info that was posted many times before.
Happy New Year!!!
Happy New Year!!!
- Group Buys
- F3 and F4 Clone PCB Reissue group buy, also F5 PCBs
