ezDAC v.1.5 Builders Thread
ezkcdude said:
I think I have a 12VAC, 1A walwart powering mine. Either 12 or 15, I'll look it up when I get home. What voltage will your regulators be set at?
Hmm, not sure yet. What voltage would you suggest?
Just another quick question... Is the ezDac single sided? (are there only components on the top side?)
Two questions before ordering parts.
1° - For T on ezDAC will PE-65612 do the job ?
Specs here : http://www.alldatasheet.com/datasheet-pdf/pdf/234300/PULSE/PE-65612.html
The PCB shows a 4 pins footprint.
All the refs quoted in the Bom's are 6 legged...
What is the orientation of the legs when ezDAC is shown on the bottom, rounded side on the outside for T ?
Do you have a Mouser ref part for this ?
2° - F1/F2 fuse on ezDual : can they be omitted ?
Those parts are hard to find and very expensive...
Bypass and have fast blow fuses behind the tranformer ?
Thanks for your advised answers ! 😉
HaLo6 said:
F1 and F2 can be ommited, I did you just have to jumper it instead. 🙂
Thanks HaLo6 !
I was just wondering about this tip for the fuses, you confirm. 😎
One question remaining, does a PE-65612 is ok as T on ezDAC ?
Specs : http://www.alldatasheet.com/datashe...E/PE-65612.html
The PCB shows 4 pins footprint, refs in Bom's have 6 legs.
Last part before closing my order sheet. 😉
Couple of questions from new be :
1. What kind of transformer should I use and what voltage on secondary?
2. How to connect transformer to AC1,AC2 and AC3 if I use transformer like 2x18V with CT?
3. How to connect Dual supply PSU ( V+ , G , V- ) with EZDAC board and where and do I need U8 and U9?
4.If I don't use OPAMP do I need U10 and U11?
Thanx in advance and sorry for my English 😀
Here's my answer to 4.
- No, if you skip the OPAMPS you don't need the regulators to power them. (and a bunch of other components)
How are you going to drive the output? You going to be going the passive route and add output transformers?
Not so sure about the your other questions, I'm going to use a walwart.
merlin2069er said:
Which components are mounted on the bottom?
The ones with a ' (prime or apostrophe). For example, see C15' and C41' below:
