External tweeter
I have seen other projects where they put a "conventional" tweeter in a open-baffle on top of the enclosure. I think it has something to do with influence of the woofer, the displaced air of the woofer can't affect the tweeter.
Raka said:
I'm trying to study the time alignment and the difraction response, but with a ready made tweeter. The adapting housing would considered as an alternative.
Any manufacturer builds this?
Swan (i think its them) build a little "pod" tweeter, and there are neo tweeters from Audax* (Morel too IB, probably others) that aren't much bigger than the dome that would be ideal for mounting in a small, minimum diffraction housing.
*TM010A1, TM010A7, TW014B5 & the TM025C1 pictured to name a few
dave
About Tweeter Mounting
Here is how Naim has done in several Loudspeakers.
This allows adjustment of the the tweeter direction.
And I imagine it avoids the tweeter to
be affected by resonances in the frontbaffle.
This is a flexible solution - to a degree, at least
Picture is from Naim SL2 user manual
/halo - likes flexible systems
reply
Although meant for pa and very high quality studio monitors,.
The FANE FST5020 slot tweeter, 8 ohm,6 khz-21khz, spl 1w at 1m 112 db,40w AES. Used with a high pass 18db 6 khz crossover,and mount it in a small wooden box.
The only downside is the price £80 inc vat each tweeter.
or AUDAX TW034X0 1 1/4 inch soft dome tweeter 34mm.70w rms,sens 1w at 1m 93 db,resonance frequency 800hz,ferrofluid cooling,8 ohm.Solid aluminium faceplate,replaceable voice coil assembly.
or AUDAX TM025F1 round dome tweeter,70w rms,8 ohm,1khz-20khz,Ferrofluid cooled voice coil,neodymium magnet [25 mm x 3mm],linear excersion +/- 0.05 mm,sens 1w at 1m 92 db.
