Explendid amplifier designed by Michael Bittner, our MikeB
There is no thermal runaway. I checked it. Biased the amp at 1A, 360 mA, 200mA, .... down to 6 mA. Finally I choosed 150mA, for distortion reason. It is quite high-biased class AB now.
The only care must be taken for stability. Lowered Cf solves it, Michael recommends 10pF for Toshibas, I recommend 3.3pF for high stability margin. Let's get in the middle, some 6.8pF.
PMA und MikeB,
MikeB said:
I simply had no smaller cap than 10pF, it just already did the job and i wanted to listen !
ilimzn, there is no runaway, i have quite small heatsinks and amp cooled down easily after turning down the volume.
Mike
Please show use some new Pictures of your amps.
My PCB are not ready until now and i miss the MJL3281A ONS, it will arrive at 03.12.2005 from Reichelt in Germany.
Today i will finish an old Elektro Project Mini-Crescendo, i bought the 2SJ50/2SK135 Mosfet und some C's and R's somtimes ago over Ebay.
It not necessary thermal runaway, just some delay in the compensation. My experience, that not easy to make perfectly compensated bias system. In my version I use two transistor bias system. It easy to adjust, just add/remove some pads between the heatsink and one of the sensor.
The double transistor version has lower internal impedance too.
sajti
My Mother Board was damaged...i was "out of the air", now new mother board and things
running well again.
Yes Pavel, those musics are very nice.... that period of time, we had the best....Bossa Nova......
Corcovado
Copacabana
I miss my home town...there are moments that i feel the need to jump over a fast Motorcicle an open the throttle all the way up!...but airplane is faster.hehe
Michael, will be ugly, but you can put 2 capacitors in series to test.
As i can see, everybody happy....ahahahahha!...i am too!
Amplifier "Warranteed"....and now with Pavel Macura, experienced Enginner signature!
hehe..... life is beautifull...isnt'it guys?
regards,
Carlos
If Symassym was a grenade!...hehe...it has pin now!
Your capacitors replace the pin into the "grenade".
hehe
Goooooooood!
Carlos
Hello guys,
not a silence, but hard work! 😀
I am preparing a long review, I was listening many hours, and now added some spectral measurements.
Preliminary info - I can say that the amplifier is very good. Michael, you only might like to strenghten power return PCB traces from those 1000uF capacitors, if you planned to make a final PCB.
Everything seems ok with symasym
Changed 22pF to 10 pF today (I had no smaller caps handy, at least two with the same value). I listened to it, but not for long. Everything seems ok now.😉
Pavel very good review of symasym. And nice work in total.
