Explendid amplifier designed by Michael Bittner, our MikeB
Sheldon said:
If you've done that without running into any noise problems, then it's a very fine job indeed.
Sheldon
Well, S/N ratio is not perfect. In fact, it may be quite bad, but some of the measured noise may be caused by not proper measuring method, so I don´k now how bad it really is.
I still wasn´t able to solve all problems with ground loops around my computer.
In real life the hum is inaudible, until you put your ear 5cm far from woofer (86 dB sens.) in very quiet room.
I'm running a multi-amped set up with a DEQX. The more channels, the more chance for ground problems. I had to experiment some to get everything to behave. Each individual amp was very quiet, but all hooked up I got some noise and Rf interference. The biggest benefit was to work out my mains connections in a star type configuration. I was able to get things very quiet.
I actually have a four way system, but the DEQX only does three way. So I made an active line level phase perfect crossover at 80Hz between the woofer and sub. In the DEQX I treat the pair as a single driver. I made the crossover circuit on a small perf board and installed one in each of two stereo Symasym amps - a lesser version of what you have done. What noise I get now is actually from the crossover circuit. It measures less than 0.5mV and can only be detected no further than 20 or so cm from the woofer (97dB). Nothing detectable from the sub. One of these days, I'll redo the ground connections in the crossovers in the pursuit of perfection.
As a practical matter, if you can't hear the hum any further than 5m away, then it's good to go.
Sheldon
Another mirrored one will make music soon.
2sk170 for input diff amp, mje15030/31 and mjl21193/4 in output stage.
It will be used in a biamp system for bass and middles, with Monitor Audio B4 speakers
MikeB said:
Nice ! 🙂 Just curious, what will drive trebles ?
Mike
Another symasym 🙂 ; the first one, with mjl15034/5 and mjw0281/0302.
Thank you for the tip. I'll remove all 1k caps.
What do you think about the 10pf that I used now? 😀 It's a very old cylindrical capacitor removed from a russian tubes Rubin TV
Thanks Mike, my Symasym is now driving two way speakers, but it is intended to be a flexible system to help me with setting different speakers.
Considering the slot system and swapable cards of the active crossover, it´s reasonable to keep each channel in perfect condition 😉
Hi Mike,
I think the 1,000 uF caps help with both filtering the PSU's and also with any current demand. This would be frequency independant.
Possibly a line of 1-470uF, a couple 100 uF and some 10's and 1 uF plus the 0.1 uF. That should present a nice low impedance across the band. Of course, it would eat up board space too!
At any rate, I think there should be something on-board that can supply current in bursts.
Have you tried this yet Mike? I know I haven't.
-Chris
