ESR Meter
Hello all--newcomer here,
I just purchased a Peak ESR70 a couple weeks ago, in deference to the "blue" kit, and found this thread while searching for more info. It works quite nicely however I found the leads to be absurdly short and the supplied crocodile (alligator here in Florida) clips to be worthless for in-circuit testing.
The lead length was an easy fix, I cut the twin coax line off of a cheap set of "ear-buds" and used both the shield and center of each cable for each pole of the tester's input.
To address the in-circuit issue I made up a set of tweezers from Popsicle sticks--nothing magical in the construction, just cut the pieces/parts to fit and glue 'em up--I built up each leaf (tweeze?) with stacked pieces to provide a grip and then applied the heat-shrink tubing.
The probe tips are 1" brass escutcheon pins bent up as needed and epoxied in place--I have since bent the probe tips inward so as to grab solder pads more forcefully. In use I clip the croc's to the exposed head of the pins.
It all works well and will calibrate to 0.00Ω with no problems...
This guy wrote the book
ESR meter page
His inexpensive little instrument opened up a whole new income stream for me (repairing switchmode PSUs)
M
URL's only available now by webarchive
ESR meter page
but also by new website
ESR meter page
more URL's:
Capacitor Lab - Bob Parker ESR Low Ohms Meter from EVB Portugal
EVB ESR METER PAGE
https://anatekinstruments.com/products/fully-assembled-anatek-blue-esr-meter-besr
A schematic for ESR meter from Italy you will find in post #1942 under
https://www.diyaudio.com/forums/parts/151392-electrolytic-capacitors-195.html#post6746282
additional advices are here
https://www.diyaudio.com/forums/equ...-advice-capacitor-esr-tester.html#post6746294
Reactions: m.abdelwanis
