I wanted to see if there is any interest in toroidal ESL step up transformers. I have more than I will need for my projects.
These potted transformers replicate the Final 0.3 transformer design. I have had very good success with them. Following are characteristics of this transformer:
A picture is also attached to this post showing what the transformer looks like.
As I mentioned, I have enough of these transformers to support a number of other projects, provided you don't require production volumes ;-)
Milan
Turns Ratio = 1:70:70 (1:140 overall)
Primary Inductance = 1.0 mH (min)
Primary Wires: Red, Black
Secondary Wires: Blue, Yellow (neutral), White
Dimensions = 3.18" (d), 1.54" (h)
Resistances:
Leakage Inductance:
Resistances:
Red:Black = .705 ohms (nominal)
Blue:Yellow = 85 ohms (nominal)
Yellow:White = 85 ohms (nominal)
Leakage Inductance:
Red:Black = 5.0 uH (max)
Blue:White = short
Blue:White = short
Milan
The dimensions for the transformer were not accurate in the original post. The correct dimensions are:
I wrote these dimensions down when I was specifying the part, but they didn't seem right on a second look. Sorry for the confusion.
Dimensions = 3.25" (d), 2.25" (h)
Hi Sheafer 🙂
I sent you a private message with some more information on these. Let me know if you need more information.
v/r
Milan
v/r
Milan
