Actually, they're quite well suited for horn loading, be it back, front or compound. In fact, they're probably better suited to such loads than many very low Q units unless the latter are run with the high output impedance amplification they are typically designed for. They'll certainly need a large horn, but since it's a relatively large driver in any case, you wouldn't expect it to be mini-monitor sized.
I assume you mean the 12LTA?
Not that it would be impossible to work something out, but no, they are not really suited to horn enclosures.
IG
I was looking at the Beta CX line and mounting the CD behind the driver for point source.
Actually, they're quite well suited for horn loading, be it back, front or compound. In fact, they're probably better suited to such loads than many very low Q units unless the latter are run with the high output impedance amplification they are typically designed for. They'll certainly need a large horn, but since it's a relatively large driver in any case, you wouldn't expect it to be mini-monitor sized.![]()
You have my attention.
Any specific links to discussion or build threads?
I suppose its mass-corner is not impossibly low at 176Hz if I look at it from this angle. Yes, gonna be one big horn.
IG
