I would go thru the TU-8550 upgrades threads as the pairing with the 8900 would be nice. I would call the sound signature as "Modern" and not like a Sunvalley Amp "Traditional Tube sound."I've read in this forum that the 8900 is best paired with the TU-8550, but I don't see it in the DIY Audio Store. Is the TU-8550 expected to be in stock any time soon?
hi, I found some reviews of Jupiter silver foil there:Has anybody tried the Jupiter silver foil vitamin-q yet I'm pretty interested in comparing them with the V-cutf I have at the moment.
@ Victor do you stock these? If so would you pm your price for a pair for my TU-8900.
Thanks Jamie
https://www.instagram.com/p/CtWxXs3NSKb/
https://www.instagram.com/p/CtWx4h_tJVA/
Does the 8550 pair well with an 8800 as well? How do I go about ordering from you directly?i still have few in stock. Diy store will have stock in mid July
Hi Victor,Matching headphone impedance/volume levels.
You can change the headphone impedance/volume levels by
simply removing the front panel and change the position of a
short pin.
https://www.flickr.com/photos/64593884@N08/
On this picture, what is the impedance? Medium Low impedance? Having 8ohms headphones, should I move the short pin to the right?
So, this jumper position is medium level for low impedance headphones, it seems. Are the jumpers like on the TU-8200R, where the jumpers select the fraction of the output, and the hi/low impedance selects the output transformer tap, except here impedance and level are combined into the jumpers?
From what I read, in the 8900 the headphone output is driven by the same tubes as the speaker output (as is the case in the 8200), so some things (like providing a load for the output transformer) have to be similar.
But the 8200 ( not R, the original) is online. As long as it's not for commercial purposes, it should be fine, no?
Hi , hope someone can give me some advice. I have recently built the TU-8550 pre amp to go with my TU-8900.
where should I set the volume control on the TU-8900 ?
Congratulations Victor on such a superb and well deserved review of the tu-8900 by Herb it was a pleasure to read.
Edit I'm looking forward to leisurely re read again tonight but this time accompanied by a night cap and some tunes from the amp.
