Elekit TU-8500 stock components vs exotic component upgrades
I forget the numbers (C?), but you only need 2 Mundorfs if you primarily use the line stage. (Two are used in the line section, two in the phono.)
Also, the op-amp chips are used in the phono as well. But an upgrade to the TI chips, if they're not too expensive, might be worthwhile if you use phono on occasion or think you might in the future.
S.
