EL34 g2 ratings
I am using a pair of Tung Sol EL34B for a guitar amp push-pull output stage, and I have come across the following: Tung Sol specifies that the limiting value for G2 voltage is 425V.
In my application, cathodes are at 0V (fixed bias), and since B+ is around 456V, the Vg2 voltages rest at 453V. Which exceeds the ratings of the manufacturer.
The bias voltage is around -40V, resulting in about 35 mA current per tube (the actual currents are 20% apart, which I think is acceptable for matching.)
Is this voltage stress really a problem? The amp has operated for about 330 hours without any noticeable changes in behaviour or problems.
This is from the Mullard data. Your use is not continuous sine wave but from time to time not far off i supose.
So to be safe, minimum 1k in series with the sreen grid.
Mona
