ECC84/6N14P for audio
How closely match is this double triodes in a single ECC84/6N14P at audio frequency? Datasheet mention about mismatch in capacitance between both triodes. But in audio frequency, does this matter? I've build a stereo cathode follower using this tube and both channel sounds the same to my ear. There's hardly any audio circuit published on this tube.
Reactions: Marco audio
Yes the 6N14P is a very close substitute to the ECC84, danzup is confusing it with the 6P14P, which is an EL84 substitute.
I'm currently playing with it, I bought ten of them cheaply on Ebay. It seems to be just fine for audio, with nice characteristics at lowish voltage. Only one thing should be kept in mind: there's a screen between the sections, which is connected to the grid of the section 1. This is intended to be used as a grounded-grid section, as the upper tube in a cascode. For audio, I do not expect any problems with this though.
Which characteristic that you like at low voltage?
I'm currently using 40V for B+ at 1.5mA in cathode follower configuration. From the datasheet, the operation region is not so linear but the sound is quite acceptable. Can you share your implementation?
Oh, your meaning of low voltage is not as low as what I think. At that voltage is should be quite linear.
For common cathode/ diff pair, the miller effect will amplify the parasitic capacitance difference between both triode. The mismatch will become worse with higher gain. No effect in audio?
Nothing that cannot be compensated relatively easily should there be a real need for it. The capacitance at the inverting input should be compensated for anyhow in the feedback network, with that in place I don't see a problem in the capacitance mismatch, as the tube's impedance is rather low at its nominal operating point.
The ECC804 is quite common in Europe, often under its alternative name 6/30L2. All the ones I have seen in the UK were made by Mazda/Brimar, whatever brand they are marked with. It is nothing like the ECC84. The ECC804 was designed for use as a timebase oscillator in TV sets, so it often turns up in boxes of assorted 300mA TV valves.
There is not much data for ECC804 on the web. It has similar characteristics to ECC82 and 6CG7. It can substitute for 6CG7 in some low current circuits but it is not an equivalent as it has higher transconductance, and much smaller anodes so can dissipate much less power. Some dealers sell a 'Mazda 6CG7' which looks very similar to ECC804, and very different from other 6CG7.
Hello ,
voila , a double cascoded differential otl amp with ECC84 and EL86 out of the book "Klein/Zaalberg ; Precision Electronics" .
Regards , Alexander .
