ECC81/12AT7 "sweet spot"
I'm playing with gsmok's simulator, it's an extremely useful tool, and it gives a lot of fun too.
Well, I'm trying to found some good operating point for the modest ECC81 tube,
I set generous 400V B+ and the forum recommended 200V on the plate. I'm also keeping an eye on vgk to be -2v or higher,
but I'm having a hard time to nail one with THD levels less than 2 to 3%.
Unless that famous "sweet spot" is all about the extremely low level of 3hd that you can hit using these parameters...?
If you start with a supply of 400V there is not much difference between a CCS and a resistance.
An example with Ra=140k and 2mA -> -Vg=1,9V , Va=125V.
Gives more than 50Vp output and a gain of 50.
The blue line is for a CCS ,almost the same.
Mona
A definite sweet spot for the 12AT7/ECC81 is 200-220 V. on the plate and an IB of 3 mA. A net load of at least 3X RP is in order.
A resistively loaded 'T7 section in the small signal circuitry of a PP amp is highly synergistic. Look at the OVERALL harmonic distortion distribution, for the unit.
I understand that we are talking 2 to 3 ma at idle
I understand that as part of a whole amplifier circuit is one thing, and to try to minimize THD as isolated voltage amplifier is another.
I'm trying the second thing, and I can drop from 2 to 3% thd (according to the simulator). Perhaps a look to the MJ book to learn how to compute THD with calculator paper and pencil is in order, but I'm too lazy 🙂)
Ian, SY: it was under my nose all the time.
The simulator displays the % THD for a given input
So, in this case, if I set 1vin the result is for input times mu.
Under this perspective, the results are Ok, and so is for the suggested operating points.
Many thanks
Cheers
J.
I think you need a better simulator. Try LTSpice which will show the output level and the distortion.
Cheers
Ian
