E182CC substituion ?
I am repairing a VTVM and have no replacement E182CC, Any substitutes (same pinout), at least, the time to debug & fix it.
Thanks.
Thanks.
The data sheet says "in many applications it is a replacement for the 5687" so that might be the place to start.
Check- http://tdsl.duncanamps.com/dcigna/tubes/sheets/amperex/7119-1h.gif
Yes, the 7119 is the alternate part number. Although often mentioned as a 5687 substitute, the 7119/E182CC is really quite different (as is the 7044). If has a higher mu and higher gm, and the plate structure is significantly larger. Both it and the 5687 make nice audio tubes, by the way.
