I'm having some problems precisely identifying, for ordering, SOIC to DIP8 adapters.
Perhaps someone can teach me how to order things correctly, and how to look for them.
My may problem is how to find a dual SOIC to DIP8 adapter. The times I have tried I got a two-single SOIC to DIP8 adapter, one SOIC on the top, one SOIC on the bottom. Which is not what I wanted.
I want to adapt a SOIC chip with a dual-opamp inside (like the OPA1656) to a DIP8 adapter. I suppose it's clear what I want, but I get tricked every time with the wrong adapter. I need to get it right!
Have a look at this Forum thread: Blind test: opamp rolling in the Pearl 3 phonostage . It talks about using SOIC-8 opamp chips, mounted on adapter boards, to plug into DIP-8 sockets on a PCB which expects thru hole opamp chips. In this particular test, the SOIC-8 chips were "anonymized" so the listeners did not know the manufacturer or the part number. But that's usually unnecessary, most applications of opamp chips don't involve blind listening tests.
The photos attached to post #1 of that thread might be helpful in some way.
You just want an adapter to go from SOIC to DIP8?
https://www.digikey.com/en/products/detail/aries-electronics/LCQT-SOIC8-8/4754588
By emulating you mean connecting, right? The DIPs do a continuous connection, not an emulation.The DIP8 is emulating a dual or typical single device?
But using two adapters in series add capacitance, induction and resistance. The capacitance is the major factor, and can only be corrected, after doing the tests and picking the best opamps, by soldering each pin to every socket.
But the best thing to do, if you made your own PCBs, is to provide the SOIC pads and the signal paths on the pcb itself.
This might get complicated if you pick single chips in your rolling.
There are countless SOIC8 to DIP8 adapters out there. These are what I found on Ali in just a few minutes...
https://www.aliexpress.us/item/2251801665905615.html
https://www.aliexpress.us/item/2251832572961805.html
https://www.aliexpress.us/item/2251832542146100.html
https://www.aliexpress.us/item/2251832634923098.html
https://www.aliexpress.us/item/3256807122524982.html
https://www.aliexpress.us/item/3256807141859633.html
https://www.aliexpress.us/item/2251832451654873.html
I know you want to use a dual op-amp, but do not search for "dual" adapters or you will find ones meant for 2x single SOIC op-amps.
Thanks for the list. Some do not show clearly the interconnections between SMD and DIP pins. This ones does:
https://www.aliexpress.us/item/1005...=scene:pcDetailTopMoreOtherSeller|query_from:
Pity it doesn't come in kits with gold-plated pins.
I had seen that. Pretty expensive if you are planning to buy several of. Starting with six of them for my comparisons.
The ones you find in Aliexpress are way less expensive, and some look quite good.
Hi Mark,Have a look at this Forum thread: Blind test: opamp rolling in the Pearl 3 phonostage . It talks about using SOIC-8 opamp chips, mounted on adapter boards, to plug into DIP-8 sockets on a PCB which expects thru hole opamp chips. In this particular test, the SOIC-8 chips were "anonymized" so the listeners did not know the manufacturer or the part number. But that's usually unnecessary, most applications of opamp chips don't involve blind listening tests.
Thank you for telling me about that thread.
But I couldn't find any specific mention or discussion about using SOIC-8 opamp chips, mounted on adapter boards, to plug into DIP-8 sockets on a PCB which expects thru hole opamp chips.
Of course I would like to read about concerns on using SOIC do DIP adapters, although I'm aware about socketing/plug-in adapters, particularly about capacitive and metal to metal contacts.
What do you want to show me? I thought it was a discussion over problems in using those adapters.
There were no problems, therefore no discussion of problems. The listeners plugged those adapters into the DIP-8 sockets on the PCB of their Pearl3 phonostage, and played music. With no problems.
A few, but not all, of the opamps tested, were available in DIP-8 packages. Fortunately, ALL of the opamps tested were available in SOIC-8 packages. Thus, for maximum anonymity, ALL opamps were purchased in SOIC-8 packages and then soldered onto adapters. Even the most ancient opamps of the batch, so old that their datasheet was released in 1971 (link) , were purchased in SOIC-8. Ordering code suffix is "D" for the SOIC-8 package on this device.
Oh, sorry. I misunderstood.
Now tell me something about the test: all opamps in the Pearl were swapped and compared, or just some of them?
Standard IC sockets aren't gold plated so you definitely don't want gold plated pins - never mix tin and gold if you want reliable connections.Thanks for the list. Some do not show clearly the interconnections between SMD and DIP pins. This ones does:
https://www.aliexpress.us/item/1005007245948148.html?spm=a2g0o.detail.pcDetailTopMoreOtherSeller.4.1629P07YP07YuQ&gps-id=pcDetailTopMoreOtherSeller&scm=1007.40050.354490.0&scm_id=1007.40050.354490.0&scm-url=1007.40050.354490.0&pvid=52c822a2-d267-474b-ba19-806698b00370&_t=gps-id😛cDetailTopMoreOtherSeller,scm-url:1007.40050.354490.0,pvid:52c822a2-d267-474b-ba19-806698b00370,tpp_buckets:668#2846#8109#1935&pdp_ext_f={"order":"120","eval":"1","sceneId":"30050"}&pdp_npi=4@dis!USD!0.62!0.59!!!4.46!4.24!@2103209b17419533142145531ee36f!12000039933553335!rec!BR!166951577!X&utparam-url=scene😛cDetailTopMoreOtherSeller|query_from:
A shot in the dark here. I have the flat little boards that I need to mount the IC that I want. No problem there, but now I need to have pin(s) soldered to the board so that the board can now be plugged into the IC socket. Surely there is a correct set of pins for this. I know that used to have some but really? Something this tiny can slip away in time, so I need some more. You guys know where I can get them or at least what they are called?
~~~~ Ok, yes, Ali express. Like everything else there are many different choices/styles that will work other applications. I found what I need for this application. I didn't want a makeshift idea. The correct type fits right into the little board just as was designed to.~~~~
- Design & Build
- Electronic Design
- Dual single SOIC to dual DIP8 adapter
