(Heh) I had assumed these were compactron tubes. Assumptions always be getting me in trouble.
Tbh I had been thinking a choke-loaded 6SN7 might be what I was looking for and @je245 was kind enough to share a suitable schematic. But maybe the Simple45 driver will do. All I want for Christmas is some bench time.
I've been using the 3.5k windings after that was suggested in another thread I started on this amp, and after determining that the DCR of my speakers was 5ohm, I swapped to the 4ohm secondary. A bit more bass.
These Hashimoto OTs make really nice bass. I might go with a larger coupling cap to add more bass as per the je245 schematic.
Thanks, all, and hope you're enjoying whatever holiday you celebrate. Lechaim and eggnog. And beeswax candles 🤘
I've been using 3.5k primary Z (Tamura F7002 + Tango NY15S) in my 2A3 and 300B projects since the 90s. That's also how I wired the Hashimoto H203Us for a friend's SE2A3 amp as well as the H203S in my mono hifi.
Happy building during the holiday season! 🙂
HC-203U primary impedance at about 40Hz reaches the nominal value due to the relatively low primary inductance (13H/3k5, 10H/2k5).These Hashimoto OTs make really nice bass. I might go with a larger coupling cap to add more bass as per the je245 schematic.
This is common on Japanese OPTs, the core is undersized.
If you boosting the lower register, the OPT distortion in this range will be growing.
