driver stage for ppp 6550's
Sounds like a good plan. ECC82s are as good as you need for cathode follower duty, IMHO. I just wouldn't use them in grounded cathode or LTP stages.
Why is that? I was just about to start working on a phase splitter design using 12AU7 with a tube based CCS for the tail. I don't know if it would work out yet (trying to drive parallel 6L6 power tubes) I just happen to have abut 30 of each of these two kinds of tubes. I can use 12ax7 if more gain is required but I'd hopped to put the AU7 types to good use.
I just think there are more linear tubes than the AU7 with similar electrical characteristics. (e.g. 6CG7, 6FQ7).
