Absolutely for tweeters -potentially less so for other units, but depends on design prioritiesI have to dive back into the books again, John Eargle has a good chapter about this if I recall well.
But if I am not mistaken, the majority of the Mms for almost any driver (woofer and tweeter) is the voice coil + former.
It certainly is for (most) tweeters.
Agreed -ideally. Although with the proliferation of wide-surround designs, < 2.5KHz or so we're losing out on the piston behaviour.Going for different materials in tweeters only has an effect on the upper range, so the break-up/resonance frequency we are talking about.
Up till about 10-15kHz it's just full on piston mode.
I was wondering what you all thought about this interesting and VERY expensive design?
I would be looking at a CD and waveguide for that price. Much better off axis.
Rob 🙂
That SS 2904 is basically the same as the venerable VIFA XT25 jobs, albeit with a refined motor assembly.
Any electrical braking would be due to back-EMF voltage making current which opposes the movement, but if you check out math and explanation here https://www.edn.com/loudspeaker-operation-the-superiority-of-current-drive-over-voltage-drive/ under title "The assumed control of cone motion" the electrical braking, or damping, would happen only around drivers main resonance, where back-EMF induced current makes force that opposes the movement. Breakup happens much above this, and the back-EMF current has phase shift to it and no braking happens, at worst it might be more than 90deg and back-EMF would actually boost some.
Any braking current would need as low circuit impedance as possible to be most effective. On cone/dome breakup its not useful current but harmful, so we should increase circuit impedance to reduce the current around breakup for better sound.
Yeah this is opposite, high output impedance amplifier would make high impedance circuit and prevent back-EMF distortion currents flowing, also would prevent the electronic damping at drivers resonance, which would result as peaking frequency response. Unless, DSP was used to reduce the peak. Also enclosure can be designed to reduce peak, also passive components can do it. This is not very marketable, as mixing and matching speakers and amps would not work very well, introduce big changes in frequency responses, or be too expensive to eliminate it, so its not done much by commercial business. But we as diyers can tailor and do what ever we wish, utilize electrical damping, utilize distortion reduction as per other constrains on the project.
You can analyze circuit impedance from drivers perspective, like in Purifi paper, and figure out how it plays out. You'd want high impedance for back-EMF above main resonance, and low impedance on the resonance to avoid effects in frequency response. Or any combination of, that best suits your application and what you have in mind. With active system and DSP one can tailor frequency response independently of circuit impedance, and tailor circuit impedance with passive components to reduce distortion, to what ever within reason. With passive speaker its double duty with passive parts and some kind of compromise on both.
Well, how big of a deal all this is? perhaps not that big in grand scheme of things but it is something to optimize if there is possibility, if target is top performance 🙂
I've read that article before, and while I agree with a lot of it, there are also simple phenomena that can be easily observed that seem to go against some of the interpretations. For instance, by holding a neodymium magnet next to a vibrating copper tube (home-made xylophone), it can be observed that the vibrations decay at a faster rate as the magnet is brought closer.
The vibrations in this case were in the kHz range. Translating that to a speaker, the eddy current is guided along a long thin wire and the amplifier closes the loop, and I see no reason why the additional mechanics of bass tuning should somehow change the operating principle.
I think the tricky point with break-up modes is that the cone resonance is perfectly aligned in phase with what the voice coil is already doing, so any 'braking' is at a minimum. That would be similar to the bass resonance, which I see got Esa Merilainen so bothered because of people constantly talking about damping, even though the system is plainly 'freewheeling' with minimum damping.
What I'm not so sure about is the accuracy of the impedance plots, which most manufacturers seem to begrudgingly show for us engineering 'sticklers'. Ever seen a super-accurate one with delta impedance on a log-log plot? On a hunch, I'd be looking for <0.1 ohm ripples from 10-20 kHz, so the usual coarse 10-20 ohm rising impedance would have to be filtered out to be able to see what's going on. Alternatively, a much higher frequency resolution to see if there are any narrow spikes, which might be missed if the plotted points are too sparse. For there to be a bell mode, the impedance has to have some kind of peak. I see no way around it.
Without speculating further, if there's a known break-up mode, I'd try that fix with a parallel notch placed in series, measure the result and go from there.
So, it would seem that at the lower frequencies of a tweeter, electrical damping is very useful,
and at the higher frequencies of a tweeter, mechanical damping is very useful.
Hi,I've read that article before, and while I agree with a lot of it, there are also simple phenomena that can be easily observed that seem to go against some of the interpretations. For instance, by holding a neodymium magnet next to a vibrating copper tube (home-made xylophone), it can be observed that the vibrations decay at a faster rate as the magnet is brought closer.
jeah Esa's motivation and attention seems to be on the current drive vs world and its tough read, has angry tone to it. Put pink glasses on and ignore the style of his and concentrate on the science part.
You can put your imagination on it, think what impedance (reactance) literally means Z = U/I? Why speaker driver has impedance peak on the low frequency even though inductance of voice coil is very low? Its all in the article, and how the impedance differs at resonance and above and how it affects what the backEMF/eddy current relates.
I'm not professional on this, but could imagine the resonating xylophone tube is system at resonance just like loudspeaker driver at its main resonance; mass is cancelled by some spring, and inductance is low, so eddy current can work as a brake as per the article. Difference is that a dome / cone breakup / mode is independent of the voice coil, connected but happens regardless. You could probably dampen a tweeter bell mode with the magnet if the dome was made out of copper 🙂 In addition dome bell mode, or cone breakup of a woofer, is at frequency where the system has high inductance. Inductance of copper tube is quite low as its single turn with air core, also resistance, so impedance at kHz is low compared to loudspeaker voice coil.
Well, I really don't know how it plays out with the xylophone tube, but Esa's dissection off speaker driver is quite logical to me at least with no question marks and plays nicely with everything else I've poked, like purifi papers, or what happens to response if you play with circuit impedance in simulator, like xo parts, amplifier output impedance etc.
Well, as long as anyone is able to utilize the knowledge for their benefit its good, its not necessary to know everything what happens under he hood. We can and could and should EQ a dome / cone breakup peak by reducing current through the voice coil by increasing series impedance at this frequency, which equalizes frequency response nice and also reduces any other current at that frequency. By other current I mean for example harmonic distortion component that motor non-linearity at lower frequency has induced in the circuit. End result is that the distortion in electrical domain is not emitted fully into acoustic domain, let alone amplified by the breakup.
@tmuikku
The reason why is very similar to a standard RLC circuit (which is the electric analog equivalent)
https://en.wikipedia.org/wiki/RLC_circuit
Any resonances or oscillation follows this exact same principle.
So there needs to be some kind or Mass component and a compliance to make something resonating.
R is just nothing more than friction.
The BL is the factor to the electrical domain.
I never thought about your explanation about how to dampen it.
Like I said before, if I remember correctly it didn't seem to effect much with woofers?
But again, that has been a while.
So I am very curious to see some more measurements of this.
I think current feedback would work well here as well.
Especially when used for (low) mid-range and up.
It doesn't make any sense to apply if for the low frequency (sub) range at all.
It's only pretty hard to implement in modern Class-D (IC) amplifiers (that are also practical and affordable).
As was noted above, it's basically the high end version of the R2604/8320 (Vifa XT25) with a different, lower-mass coating, a different central plug, and the Revelator motor. It has better higher-order HD performance on the low end thanks to that motor, although that's also partly skewed by it having a better-damped LF. You're paying a heck of a premium for the build quality & that better HD, though it is a better tweeter. Still has that elevated HD2 of all wide-surround (or 'only surround' in the case of ring radiators) tweeters though.I was wondering what you all thought about this interesting and VERY expensive design?
it's expensive for what it is, but you maybe can expect some consistancy on the building side and datasheet result
You could buy 10 XT25s for one pair; get perfect matching from 2 of them, and sell the other 8 🤣
You can. But you also get that from many much cheaper tweeters too -incuding the aforementioned 8320.it's expensive for what it is, but you maybe can expect some consistancy on the building side and datasheet result
for sure, I can't affoard this iluminator SS. One that had my eyes is the 83000 at 45 euros (single magnet one) which seems to have a cleaner low end than the doublle magnet 833000. Seen also waveguided in the Heissmann wave guide-tweeters test ! The SB26CDC should be less hard sounding though I surmise.
Revelator. 😉for sure, I can't affoard this iluminator SS.
How do you classify 'cleaner'?is the 83000 at 45 euros (single magnet one) which seems to have a cleaner low end than the doublle magnet 833000
I don't know what that means, so no idea, although with the demise of the Peerless DA25TX it's technically speaking about the best affordable 1in hard-dome tweeter widely available -with the Seas 27TBC/G and 27TAC/GB lurking in the offing.The SB26CDC should be less hard sounding though I surmise.
You do know you are giving advice to someone who believes cement resistors prevent tweeters from reproducing details. 🙂
cleaner waterfall, look at Dibirama the waterfall of the 83000, its low end above 2k hz is cleaner (faster and better damping) than the 833000
Not a believing, nore a biass. But if you cannot hear a difference with a tweeter between a basic cement vs MOX vs Ayrton Perry Mundorf Supreme resistor by yourself, there may be several cause : not so resolving cable (between source/amp,pre or loudspeakers as well), and or source resolution, and or amp resolution & drive, and or tweeter itself or the quality of choice of passive other parts -coils and caps-. With my current aluminum tweeter and mid, it is clearly different ! Yes, more veillled sound with basic cement in my setup. More details with the Mundorf Supreme resistor, especially details in the decays. That is simple as that, my setup is so resolving than each different cables or parts be it active or passive from the source can be heard... or several personn have biass, evenn the non audio ones whom are musicians and heard it at home. Could be the age of your ears as well, go figure; anyway not a biass here or people has collective hallucinations at home (no mushrooms parties)
How can you have a low end above 2KHz?cleaner waterfall, look at Dibirama the waterfall of the 83000, its low end above 2k hz is cleaner (faster and better damping) than the 833000
- Dome tweeter: Auminium vs Magnesium... marketing
