Hi
Is anyone here using Dolby 7.1, with 2 rear mono channels:
- in practise is it much (any?) better than 5.1 or 6.1, etc,
- are the quality or matching of the rear speakers that important?
There's a lot around with 6.1 but have never seen a 7.1 on a DVD. Doesn't it just make it up from the data on standard DVDs? Blueray has 7.1 capabilities I think.
In the end, gave 6.1 the flick and back to 4.1.
> Have you actually found a disc with 6.1 or 7.1 on then?
No, I just bought a 2nd hand 7.1 receiver. Not chosen for its 7.1, but for its Audyssey MultEQ. http://www.audyssey.com/technology/index.html
But as it has a 7 amp channels, I thought *if it’s "useful" - I’d hook up some rears
Cheers
Cheers
Top Gun and the later Titanic are both DTS 6.1 and there are others here which I can't remember. AFAIK, 7.1 is the same as 6.1 but with 2 mono rear channels instead of 1 (see the pic).
You also find a lot that show 5.1 on the liner notes but are EX such as The Corpse Bride. These have the EX flag that automatically activates the EX decoding in the AV receiver or amp. You'd be surprised at how many there are and you don't know until you pop in the DVD and when the movie starts, it shows EX or ES and the centre rear icon is activated. I believe it's not discrete like 6.1 but close enough.
With Blue Ray which can do Dollby TrueHD, DTS-HD master etc, there will be a lot of 7.1 but the AV amp will need to have the decoder to suit.
It's getting nuts and anyone for 24.4 and beyond?
It is indeed a sad way the marketing is taking technology. Anything more than 5.1 is just unecessary in normal people's homes. In fact you can easily get away with 4.1 really.
Rabbitz,
I recall you have a HT setup, especially thoughtful in the rears, but not exactly what . .
Do you have a web link?
(Due to SAF and door location I can’t accommodate a centre, which is no problem.
I’ll use high clarity three ways and a phantom centre).
So (apart from the 0.1 LFE) it could be:
Front L R
Side L R
Rear: either one or two
ie 5.1 or 6.1
Or
Front L R
Back L R
ie, a different sort of 4.1
Which is better with ‘most formats’?
Front L R
Side L R
ie 5.1 or 6.1
Or
Front L R
Back L R
Yep.... 4.1 is what I went back to and I found it tonally better and better clarity (and dialogue) as I view on axis with LR front next to the screen. Side benefit.... more room for my stereo gear. 🙂
Binned both centre speakers which used the same mid-woofers as the rest so tonally they should have been OK. Tweeters were different, SEAS 27TTFC vs Vifa D25NC but the difference would be moot. I think the difficulty is to get the positioning right for the LCR (same plane, heights etc) and that's impossible in most viewing areas.... well it was here if I wanted to see the screen.
There's an interesting little note on centres and 4.1 in this marketing blurb but it lines up with my experiences. The moral is, if you can't do the centre exactly right, don't do it at all. 😉 Of course a lot will disagree but that's life.
http://www.zuaudio.com/loudspeakers/druid-center.html
.... back to the original topic.... what was it again? 😕
rabbitz
Thanks again for chiming in.
The general topic (not thought and stated clearly up front) is if your amp is capable of 7.1, how many speakers should you sensibly use?
Better (best) clarity is also my aim.
I’m also skipping the centre.
Is the 4.1 you settled on:
Front L R
Back L R
Or
Front L R
Side L R
Ie what angle are the back two from you, the listener?
Also, how close tonally need the back or side speakers be to the front?
(do you have a link or post the reflects your current views?)
Front L R
Back L R
Or
Front L R
Side L R
otto88
Unfortunately I have a wall directly behind the viewing area and an awkward side wall arrangement which limits the rear speakers that can be used.
I place a priority on atmoshere from rear speakers more than direct sound so needed an arrangement that would hide the location of the speakers.... a sort of pseudo null as they are hidden by the sofa.... to create a more diffused pattern.
The end result was side firing with a slight tilt backwards. The centre rear when it was there fired up to the ceiling. Most of the sound I hear is reflected sound but is still able to provide location and steering when required. See the pic even though the quality of the shot is not real good. You never know they are there so very SAF. A lot have had great success with rears that fire upwards.
I had a visitor from Tassy who has never heard a HT system (or has hardly ever been to the movies from the reaction). I played the scene from Top Gun after the flameout when the F-14 goes into a flat spin. The steering and effect was very real and she freaked out... mission accomplished. 😀
It's hard to say what works best as each room, furnishings are different but you just have to experiment. I think if you use side LR then I think the rear LR are required.
I needed clear dialogue as my hearing is not as good as what it was especially when other action is happening, good soundstage LR and front to back, good steering and atmoshere and the final result is very good and satisfying with 4.1.
I've read a big mistake is to have the front LR too far apart as they should be next to the screen to be convincing as the soundstage has to lock to the screen.
BTW... Kendal has finished your speaker but has lost your phone number so he can't let your know.
The 4.1 is
front LR
rear LR
with sub out of sight and fires sideways into a wall
I was joking about the topic as I got lost rambling on. 😉
I think it's important to use the same mid-woofer or similar throughout. The fronts of course are the most important and I would use at least the same brand / type for the rears (for say 300Hz - 3kHz) but can be much smaller as these are normally set to small. All my 4 are set to small and I let the sub handle the LFE channel.
The speakers in the pic next the the screen are the front LR and are only 5" 2-ways.... SEAS 27TTFC / Peerless 850488.... plenty of go, clear, good dialogue and only handle from 90Hz up.
You can see the angle of the rears in previous post and as I can't see them from the seated position, I can't locate them acoustically as well.
One other thing.... I only have to cater for an audience of 2 (plus 1 dog) so it makes it very easy as there is no off-axis. As soon as off-axis comes into it, it's a whole new game.
front LR
rear LR
rabbitz
You’ve confirmed my loose hunches:
> atmosphere from rear speakers
> you never know they are there so very SAF 🙂
ditto
and one thing I hadn’t thought of, which its better to know about up front:
(Thanks very much for the news re Kendal too!)
ditto
rabbitz
this surprised me
As clear dialogue is more important to me than general action/ background, and intelligibility is most concentrated in the range 2 – 4 Khz, I’d guessed that it's much more important to use the same *tweeters throughout.
I have two pairs of the same tweeters, but none of the same mid-woofers. (And my (2nd hand or bought on special) mid-woofers are too $$ to get extras) so thought matching the fronts and sides tweeters would give “enough” matching.
Though the front intended mid-woofers are mag cone, and the intended sides metal cones, maybe that’s close enough . .
> The fronts of course are the most important, and I would use at least the same brand / type for the rears (for say 300 Hz – 3 kHz) but can be much smaller as these are normally set to small.
I thought if the rear channel(s) are mostly effects, matching there is much less important than matching fronts and sides – no?
Lucky you, my tribe can get big, but that’s another issue
Cheers
this surprised me
Cheers
In the Loudspeaker Design Cookbook, there is a HT speaker design and he's used the same mid-woofer throughout but uses different tweeters on the rears due to the cost and comments that they are of similar type so the timbre would be similar. There's also a good section on HT speakers in general and dedicates a lot time to rear speakers.
The point is, when a sound starts at the front as a "WOOOOSH" you don't want it to turn into "wiiiish" when it hits the back speakers. I think the majority of the energy would be coming from the mid-woofer rather that the tweeter. As long as the mid-woofer has a similar tonal sound, close enough as it's HT after all and not stereo music. At one point I had some Vifa TC mid-woofers at the back and tonally worked quite fine with the Peerless on the fronts. The rears do not have the priority of the fronts and are along for the ride only.
Important to lock the sound to the screen as you don't want a car screeching to a halt at the left side of the screen having the sound coming from 1m to the left. It's very impressive on demos with a wide soundstage but not very convincing. A woman talking with a 3m wide mouth is not appealing. 😉
Have a look at the THX spec and work backwards. Also some good info on the Dolby site.
With a tribe.... that's easy. You grab the best spot (plus remote) and shout "Movie's about to start" and they can scramble. 😀 Kids don't give a rats about the sound as they are taken by the visuals.
- Digital Line Level
- Dolby 7.1
