Does this explain what generates gravity?
I'm curious to know why the Universe is depicted in such a way.
All three diagrams simply illustrate a timeline.
The top one, which I submitted, best gives the detail of the composition of the Universe during each of its epochs.
Attached, is a logarithmic map of the observable Universe. (Note that the observable Universe is finite in its radius while the actual Universe is probably infinite.)
The map is highly detailed and is annotated, so please expand it.
In every direction we look outwards from our solar system we are peering back through time towards the Cosmic Microwave Background - the remnants of the Big Bang itself.
Note that it should not be interpreted that the Sun is at the centre of the Universe!
Didn't Einstein once remark the universe is infinite but bounded? Whatever that is intended to mean.
The first Friedmann model of the expanding universe suggests that the universe is not infinite in space, but neither does it have a boundary. Gravity is so strong that spacetime is bent round on itself. In this model, gravity would eventually halt the expansion of the universe, leading to its collapse.
https://www.britannica.com/science/Friedmann-universe
EDITED
There's a good description of what an infinite, but unbounded Universe means here:
https://physics.stackexchange.com/questions/247864/what-does-finite-but-unbounded-universe-mean
It takes us back to the topology of the Universe that we considered in some depth earlier in the thread.
If the Universe is closed in on itself in all three dimensions like a three-dimensional torus, we could point a spaceship in one direction and eventually return to where we started.
The actual shape of a 3-torus universe is impossible to represent or imagine, but we can use the analogy of the 2-torus shown below instead.
https://blogs.scientificamerican.com/roots-of-unity/a-few-of-my-favorite-spaces-the-torus/
It uses a circle.
That's a useful and, as you say, simple illustration.
A finite and unbounded universe would have no edge.
In such a universe a spaceship travelling in one direction will eventually return to where it started.
This is the topology of the video game Asteroids, where a spaceship which goes off the screen on one side appears back on the other.
But the again - as for the circle in the picture - there is something outside it... just because something with mass would return, it doesn't mean that there isn't something to explore outside the circle for a mass-less entity - and thus - what's inside the circle isn't everything.
The inside or outside of the circle has no physical meaning - space is represented by the circumference of the circle.
Just like in the more sophisticated 2-torus representation where space is represented by the surface of the doughnut.
I reckon it's really a sphere.
Topologists, who refer to the dimensions of the surface itself, regard a circle as a one dimensional sphere and a ball as a two dimensional sphere.
The Universe could be a three dimensional sphere, i.e., a two dimensional sphere, but one dimension up.
A three dimensional sphere is hard, if not impossible, to visualise and that's why a circle and a ball are used as analogies.
https://mathworld.wolfram.com/Hypersphere.html
Learning all the time! 🤓
VERY INTERESTING MATHEMATICS
I want someone (or more) to watch the following YouTube video (starting about 5 min. in)
to decipher for me the exact number/fraction of the dip being explained , where fall becomes rise.
If the exact number is found >
I TRUELY BELIEVE THIS NUMBER IS AS IMPORTANT AS Pi
First off, messing with calculators is a fishy proof. What about truncating errors ????
I understand you are interested in the minimum of the fonction x^x.
The usual approch is to find the derivative of x^x ( it seems not obvious to me, but doable with good neurones).
Then solve for 0.
It boils to:
x such that d( x^x )/dx = 0
You will find all answers, with valid proofs, here:
Reactions: Audio>X
No. It's another type of dimension but just 2D.. Follow the line which represents all space and you eventually get back to where you started. There is nothing behind space.
😉 I reckon it's really a sphere. May as well explain why. If it's expanding space would increasing.
It's gravity the caters for the bending - right?
But if a particle which isn't affected by gravity is on a journey, what trajectory does it take?
What if the radius relates to time? It becomes an unbounded 3D space other than the chance of a big crunch may return but it seems expansion is not defeated by gravity and never has been even from an infinitely small point that may or may not have existed. However gravity does have an effect on time as can speed. Time is often referred to as an arrow. Something that a continuum of some sort moves through. Space time is one. A term Minkowski came up with but bear in mind what Einstein's theory means. Certain aspects are linked.
Going back to the bounded but unbounded circle. Sweep a 2D shape around it to form as space but that 2D space is expanding so the circumference must do as well. If so it's not bounded, the unbounded lengths also vary as well. It can't have a infinite radius it needs lots of them. So a simplistic view just doesn't work out so find one that does. That's astrophysics in many areas.
😉 A Hoyle idea was partly defeated by the need for matter to be continuously created. Not an area I have looked into. Not flavour of the month so finding out what it means may be tricky. Yet we are looking for more matter and a bit of energy to go with it.
