Does this explain what generates gravity?
The complex frequency domain?
Hopefully that's not too complex! https://en.wikipedia.org/wiki/Frequency_domain
Reactions: Bonsai
Capacitors are measured in Farads. "The capacitance of a capacitor is one farad when one coulomb of electricity changes the potential between the plates by one volt." Britannia One coulomb is "equal to the quantity of electricity conveyed in one SECOND by a current of one ampere." Oxford Languages
coulomb = 6.241509074 x 10^18 electron charges ---> SI definition
second = duration of 9192631770 cycles of caesium transition frequency ---> SI definition
ampere = coulomb / second --> derived unit
ampere = 6.241509074 x 10^18 electron charges per second
Perhaps I'll understand your 'time is created through energy' hypothesis before I kick the bucket. 🤓
Although I don't think your argument quite holds water!
We learned earlier, when looking at telescope liquid mirrors, that water swirling in a bucket will take on a parabolic shape.
It was an analogy Galu - and I made that clear!
Use the Laplace transform to the complex frequency s domain. It's much easier than in the time domain.
And you can then calculate the transfer function just with Kirchhoff''s laws.
And then, if you want, even transfer the result back to the time domain with the inverse Laplace transform.
So you only need arithmetic instead of differential equations.
My point is that you can't avoid time as a parameter. FREQUENCY implies time. Tell me how you explain frequency without time!
You mentioned transferring back to the TIME domain. Explain how electronic filters work without time!
I shouldn't have to explain this to a group of engineers.
You avoided the definition of a farad. The definition references time.
Even your definition of ampere references time. You can't avoid it!
I guess you could summarise post #2090 as time and energy being fundamentally linked at some deep level...
I notice, Bonsai, that while two engineers are having a spat over time, you are getting off scot-free!
I did the calculation a few months ago of the universes expansion rate converted to everyday distances and it’s something like 10^-30 (IIRC) per second per meter.
So, we are talking about converting (km/s)/Mpc to (m/s)/m.
The SI unit of the Hubble constant would therefore be s^-1.
I cheated and read that 67 (km/s)/Mpc is about equal to 2.2 x 10^-18 s^-1.
There can be little argument that the latter number is a lot harder to remember that 67!
Reactions: Bonsai
Ah yes - that's more like the number I had.
The problem here is the universe doesn't work in m/s^-1 or km/s^-1 per Mpc. I think it would be good to think about it instead in some sort of natural units. But which one?
My point is that you can't avoid time as a parameter. FREQUENCY implies time. Tell me how you explain frequency without time! You mentioned transferring back to the TIME domain. Explain how electronic filters work without time!
Filters can be designed entirely in the complex frequency s domain. It's not necessary to transform to the time domain.
Example of a low pass RC filter:
T(s) = (1/sC) / ( R + (1/sC) )
= 1 / ( 1 + sRC )
Filter has one pole at s = -1 / (RC)
Or if you prefer, one pole at f = 1 / (2π RC )
= 1 / ( 1 + sRC )
Frequency is dependent on time. Capacitance parameters are dependent on time. Every time you invoke frequency or capacitance, you are using time in your equations.
No matter what domain you use, time as a real life parameter is unavoidable.
SI defines time in terms of frequency !!
So all of the derived units are based on that frequency.
Recall that time depends upon the observer, see relativity.
But the exact 9192631770 cycles of caesium does not depend on the observer,
since the natural numbers are universal, so frequency is regarded as more fundamental than time by SI.
Unfortunately, I'm out of time.
I know about the SI definition. It is used because radioactive decay is very repeatable and precise.
Frequency is not more fundamental than time. Radioactive decay of cesium is used because of the precision it offers. The most precise and accurate clocks are cesium clocks.
I'm beginning to think you guys are pulling my leg. Are we engineers or are we Devo?
