I built a First Watt B1 pre-amp using parts I had in stock, which included a rather small 24V/75mA (1,8VA) power transformer.
First I figure this small transformer was just temporary, needed to be changed for a more powerfull one, ones I got my hands on it. But then I start thinking.
Since the B1 works under close to constant curent (12 mA), and I have a CCS/TL431 based shuntregulator (32 mA contant current CCS and 20mA drained through the shunt) with a very low output impedance (0,2 Ohms), is there any need for a beffyer power transformer?
The load is like 18V and 18mA, so 1k.
There is (on Pass's plan) a 15,000uFd capacitor on the rail.
1k with 15,000uFd is a 15 second time-constant. MUCH longer than typical audio events.
If this were a class B stage we would need more thinking. But it is Pure A. The preamp current averages to no-change over each signal cycle.
"beef"
"beef"
Is this correctly understud?
Thanks PRR
Did you ment that a small transformer is okay as long as it can suply with voltage and current with no signal applyed (quescent current) ?
And that is because the last cap is acting a charge resevoar to take care of (if any due to the class A working point) current swing.
Thanks PRR
In the plan in the first post: there is a "CCS" between transformer and amplifier. This makes deliberate SAG ("un-beefy"). Your only concern is to get enough DC from the rectifier to cover losses in resistors and CCS to get the design voltage at the amplifier.
> best C, is the one that eliminates hum, and no more.
Hum is never totally eliminated. You can only "make it too small to hear".
I have a feeling we are using magic spells instead of actually understanding.
- Does a "stiff" PSU rely on a beffy transformer?
