I built a First Watt B1 pre-amp using parts I had in stock, which included a rather small 24V/75mA (1,8VA) power transformer.
First I figure this small transformer was just temporary, needed to be changed for a more powerfull one, ones I got my hands on it. But then I start thinking.
Since the B1 works under close to constant curent (12 mA), and I have a CCS/TL431 based shuntregulator (32 mA contant current CCS and 20mA drained through the shunt) with a very low output impedance (0,2 Ohms), is there any need for a beffyer power transformer?
The load is like 18V and 18mA, so 1k.
There is (on Pass's plan) a 15,000uFd capacitor on the rail.
1k with 15,000uFd is a 15 second time-constant. MUCH longer than typical audio events.
If this were a class B stage we would need more thinking. But it is Pure A. The preamp current averages to no-change over each signal cycle.
"beef"
"beef"
Is this correctly understud?
Thanks PRR
Did you ment that a small transformer is okay as long as it can suply with voltage and current with no signal applyed (quescent current) ?
And that is because the last cap is acting a charge resevoar to take care of (if any due to the class A working point) current swing.
Thanks PRR
A beefier transformer has lower output impedance. The large C on the board also has low impedance. I think it is case of diminishing returns. It probably does make a difference but whether or not you could hear it ???
Honest question - I was under the impression that the best C, is the one that eliminates hum, and no more. Is that wrong? (ed. that's probably not stiff I'm guessing.)
In the plan in the first post: there is a "CCS" between transformer and amplifier. This makes deliberate SAG ("un-beefy"). Your only concern is to get enough DC from the rectifier to cover losses in resistors and CCS to get the design voltage at the amplifier.
Hum is never totally eliminated. You can only "make it too small to hear".
I have a feeling we are using magic spells instead of actually understanding.
- Does a "stiff" PSU rely on a beffy transformer?
