Cheers !
The Highballs [spherical ones on chrome stands] are excellent little speakers and do kick out a lot of bass for their size. All in all a successful exercise in lifestyle speakers, thogh maybe a bit bright for many tastes with newer AV amps [my older Arcam AV50 partners them very well though].
The Londballs [tall ones in Zebrano and Wenge] sound superb. Very good extension, in fact surprising as you forget it's all coming from the back of one tiny 4" driver. Vocals sound very natural and since stuffing about 50% of the line, there seems to be no upper zing that the Jordan metal drivers can sometimes tend to have.
I really do love these speakers and never tire of looking at them.
I want to push my endeavours further and start on some electronic kit, well not me personally but my colleage who is an electronic engineer [I just do the aesthetics]
I have in mind a 5 way amp with built in high quality phono stage. Following that a matching DVD player using a second hand unit as a basis.
There is one DIY company in Denmarkk owned by a woman: www.frequence-shop.dk
It seems updated very frequent and have some interesting projects and parts.
zx6r.j1 said:
Thanx for that -- i have been wondering for sometime what the Dared (aka FatBoy) used for a power amp.
I'm curious to see a close up of the front and back of the drivers in your open baffle.
dave
I'll post few more pictures when I get back from my travel.
Meanwhile I did put up some vids:
http://youtube.com/watch?v=pm04EJdLOeg
ELSINORE LOUDSPEAKER PROJECT
www.customanalogue.com/elsinore/elsinore_index.htm
FOCUSSED DRIVER ARRAY ABLE TO PRODUCE SQUARE WAVES AT THE LISTENING POSITION:
IMPERVIOUS TO HIGH OUTPUT IMPEDANCE AMPLIFIERS - ZERO TO 3 OHM:
MINIMUM PHASE - TRANSIENT PERFECT - CROSSOVER:
MINIMUM PHASE:
ACTUAL PHASE (above 200Hz):
"RENEGADE TWEETER THEORY":
Three and a half years in the making - now in their mature Mark 3 guise. The basic idea was to design a loudspeaker with Ultra-Low Dynamic Compression. This means cool running voice coils, benign load on amplifiers, even modest amplifiers capable of awesome dynamics. Flat in room response down to 25 Hertz - no real need for SubWoofers.
* * * * * * * * * * * * * * * * VERY POWERFUL SOUND * * * * * * * * * * * * * * * *
MINIMUM PHASE:
Aethers, Orient Express, Sunflowers...
still growing...
http://undefinition.googlepages.com/diy
-Paul Carmody
still growing...
-Paul Carmody
http://loudspeakers.we.bs/
fivestring said:An externally hosted image should be here but it was not working when we last tested it.
Hey, I like the chromed half-pipe sides. I am planning a project that will be similar in concept. See www.diyaudio.com/forums/showthread.php?s=&threadid=127911
I plan to roll the cabinets in a nice wood veneer. Perhaps "tiger myrtle" if I can afford it.
Can you give me a link to the builder of those speakers?
Doug
Doug
Hi Doug,
I built the loudspeakers in question, but only one prototype piece was made and eventually it went to trash can. Actually I was more interested in effect it would have on box diffraction and frequency response. As it turns out, this is much better than with the ordinary square boxes. Perhaps you should also consider the type of enclosure I included in the attachment.
regards
Miro
Sorry, it seems it was too big file, you can download it from
here
Thanks Miro, but is the link correct?
The cabinet pictured in the Cheap Trick article doesn't appear to be the same as the chrome-pipe edged cabinet.
Doug
Doug
Sorry Doug, it was just meant as a cabinet suggestion. Mine was just 1.5mm steel
curved to a round shape. However, I would not go that route again, it is very demanding to make it without leaks.
Miro
Miro
fivestring said:Sorry Doug, it was just meant as a cabinet suggestion. Mine was just 1.5mm steel
Miro
Thanks Miro.
If & when I get mine finished, I'll post here to show you the result.
cheers
Doug
Sublimes from Brasil
Dears,
DAD Sublimes
http://www.diyaudio.com.br/search/label/DAD Sublimes
DAD Sublimes Clones
http://www.diyaudio.com.br/search/label/DAD Sublimes - Clones
Tks,
Renato
Rio de Janeiro - Brazil
Dears,
DAD Sublimes
DAD Sublimes Clones
Tks,
Renato
http://www.check.wz.cz/
You might be interested in some measurements, more to add in fullness of time.
It's written in Czech, you can use google translator, sometimes funny but usually readable. If I find great rise in visit rate, I might translate it in English. Well i hope in better English than google 🙂.
- DIY web pages
