DIY Waveguide loudspeaker kit
"omni" for surround?
How about a monopole, but that is located close to the ceiling but fired upwards, so that it is reflected off of the ceiling to be more diffuse?
Sound crazy?
That is a gr research design that intrigues me. It may not be original to Danny, but it was the first that I have seen it.
http://www.gr-research.com/index.asp?PageAction=VIEWPROD&ProdID=113
Seems it would waste one of the main points of the waveguide though - CD.
And mixing these kits with that design would lose the consistent timbre matching that is required.
-Tony
By "solution" do you mean the axial hole which is in the field of listening for the center channel? No, I haven't dealt with that yet. On my system, its not a big deal since the axial hole on the 15" waveguide is pretty benign. On the Nathans and Abbeys, I have not sold very many center channels to be concenred about. But you raise a good point that I should get back to. The thing to do would be to optimize the crossover for a better axial response for the center channel. Thats easy enough and could be made to yield a much better axial response, albeit a slightly degraded off axis one. Putting the speaker on its side and tilting it up might be another improvement.
Hey I bought one to use as a center. What are we talking about here, did I miss something. What axial hole are you referring to. If I place it on its side there is a hole? What if it's placed behind the screen but oriented as normal? How about below the screen, angled up, again, oriented vertically, as normal?
Matt
Yes, the center speaker might be improved with a slight crossover change. I'm just now looking at that.
There is an axial hole in the response - right on axis. So if you sit right on axis to the center speaker there is a dip in the direct field response. How audible this effect is is unknown.
I'll let you know if I can recommend a crossover change.
Maybe then as a temporary fix I should lay it on it's side. You mentioned tipping it up, but I wonder if no angle or very little is better yet to maintain the off axis response? I would assume avoiding ground reflections a good thing, but then, isn't carpet and a carpet pad pretty absorbent?
As to the floor reflection, I found that it took a pad about 2-3 inches thick to work well. And then there is the ceiling.
"How about below the screen, angled up, again, oriented vertically, as normal?"
Really determined to get that axial hole aimed at you so you can fix it, eh? 🙂
I'm really surprised at this talk of putting the center on it's side and the resulting asymmetry in horizontal response.
Why not just face it directly forward and let the axial hole hit you in the knees?
I would either live with the hole, or modify the crossover as I sugggested to make it smaller. I wouldn't lay the speakers on thier sides or move them down or anything else like this. Your creating bigger problems than the one your trying to fix.
Thats audio for you, people get fixated on a small problem and create bigger problems trying to fix the smaller one. I see this over and over and over again. When one has no idea how to "scale" the problems in terms of audibility then this is inevitable.
Hey I didn't know it was a problem until someone else mentioned it. Admittedly the term hole had me a bit nervous. I am finding there to be a pretty large difference in tonality with varying degrees of vertical axis. In other words, the stand up sit down test creates very noticeable differences, and so I would think having the speakers on the floor pointing straight ahead would cause it to sound tonally different from the left and right speakers.
Correct, which is why I wouldn't do it. Keep the three fronts at the same level and then change the crossover for the center if you notice anything, but you have to be dead on center. The crossover change will degrade the power response, but improve the axial response. Which is better for you depends on the room and the setup.
It's probably time I give an update about my experiences thus far with the Nathan 10s. I've had them up and running for two months now and I'm still loving them.
Placement in my room is not ideal. The speakers are only 20" off the front wall and my listening position is near the back wall. Unfortunately this is not something I can change easily due to big entryways on two walls and a doorway to the kitchen on another.
The Nathans sit on either side of my fireplace, with my TV hanging above the mantle. The Nathans are about 7-8 ft from each other and about 5 feet from the side walls. They sit on stands that bring the midpoint between the waveguide and woofer to ear level.
Below is a picture from shortly after I set them up. They are currently toed in slightly more than they are in the picture and I pulled forward to get them away from the front wall and moved the leather chair away a bit. They are now at exactly 45 degrees toe in, which puts the crossing point about 4.5ft in front of the center listening position.
My main source is the optical output of an airport express being fed music from my Mac Pro. Secondary source is my blu ray player. Receiver is a Denon 2809ci. Subwoofer processing is handled by a DCX2496 and a DEQ2496. Subwoofer is a Maelstrom X in a 6 cubic foot sealed enclosure, powered by an EP2500. Probably worth noting that my crossover uses the 1.0uf cap on the compression driver. Only mods I did to the speakers were using a Speakon connection on the rear panel and increasing the roundover to 1.25" radius.
The system sounds fantastic. I think I've used the word effortless before to describe them and that still holds as my primary description. Sometimes I play certain music at pretty high levels (wife calls it "rocking out" 😀) and these speakers never even flinch. They sound absolutely fantastic at levels I've never even dared to try with my previous speakers.
I'm also a sucker for good female vocals and these speakers do not disappoint. My favorite tracks from Natalie Merchant, Rosie Thomas, Neko Case, Diana Krall, etc. all sound wonderful. Karen O from the Yeah Yeah Yeah's just makes me grin ear to ear on the Nathans. That sort of music, epitomizes the strengths of the Nathan 10s in my opinion. Hard rock power but such a pleasing response that never sounds harsh. They seem to fit perfectly with the full range of my music collection.
The imaging is perfect, as long as I have some absorption panels in place on the front wall and directly behind my head on the back wall. I hope to make the panels permanent in the next few weeks but my wife and I are still discussing how to do so and maintain some reasonable aesthetics.
I'm experiencing the same effect that has been described previously as a result of the speakers crossing in front of the listener. The response seems very even as you slide along the couch between the speakers. Sitting on the front of my coffee table, at the intersection of the on axis paths, is a pretty interesting sound, but not as good as the listening position.
The downsides thus far:
1) my room configuration
2) all the stuff I've found that rattles in my house
3) the realizations that some of my previous investments were misdirected
4) my desire to buy the Summas
In all seriousness, this is the happiest I have ever been with a pair of loudspeakers.
The work I'd like to do going forward is with the room itself and the addition of a couple infinite baffle manifolds. I had 3 subs in the room, but my wife eventually said 2 had to go. The IB manifolds suit her just fine because they will be effectively invisible aside from a couple extra air return grates. Taming the early reflections off the front wall and the reflections off the wall behind the couch really does make a lot of difference, so that needs to be made permanent in the near future as well.
Thanks again to Earl for making these available to us. It really has been a great experience.
This is unrelated to the waveguide kits, but could be an option for the subwoofer kits. A bandpass sub designed to be hidden and with the port made up of a flexible tube that connects to an air vent. I believe James loudspeakers and Speaker Craft have done this, and I think it's a somewhat ingenious idea. The flexible port needs to be something where the length can be kept constant, but otherwise I don't seem major problems in implementing this in a kit or diy. I think it has the potential to be a better idea than the IB manifolds since they should be cheaper to implement and more efficient.
I have Summas and I am jealous of how small your speakers are! Even with a dedicated listening room thats the size of a small apartment (600sf), it's tough to arrange the room around the Summas.
I heartily recommend getting lots of subs - I started with three and now I have eight. It's the biggest improvement you can make IMHO. Even a Danley DTS-20 would have a hard time keeping up with the Summas, you really need some serious subwoofers to keep up with the mains.
Glad to hear you like the new system!
If anyone doubts that such a huge speaker can "image", here's something funny that happened this weekend.
I was watching this weeks episode of "Lost", and there's a scene with a lot of ambient information. Basically it's a scene where someone sneaks up on one of the characters from behind.
During the scene my girlfriend actually looked over her shoulder!
I asked her why she did that, and she said "I thought I heard someone in the room."
Crazy huh? I've never had speakers which imaged like this. (This is a two channel set up also. No rear speakers.)
Here's the episode, if anyone saw it, it was the scene with Sun, Jack, Ben, and Sayid.
http://www.eonline.com/uberblog/wat...m_medium=rssfeeds&utm_campaign=rss_topstories
"Image"
Patrick,
funny that you should mention your recent 'imaging' experience with the bigger Summa as i recently had a very similar experience with my half finished Nathans. During the first 10-15 seconds of a live Sarah McLachlan album i recently purchased there is a watch alarm beeping in the audience. My first reaction was that my "G-Shock" Casio watch that i wear to work everyday was going off at an unusual time. I dont have the slightest idea how to set the alarm and it has gone off at midnight for the 5+ years i have owned it. Puzzled as to why the alarm was going off mid day I started looking for the watch over to the left side of the couch where I had clearly heard the sound coming from. Only then did i realize that the watch alarm was coming from the audience in the recording. Spooky and way cool...
Regards, Daniel.
P.S. A question for Earl. When do you expect the Harpers to be available ? I think i have a couple of potential customers and want a pair myself.
