Hi all
Could someone point me to a qualitative tube preamp kit at a good price?
I would be using it in front a hypex amps
I just need one IN to connect a dac
In finish products, i have only seen some expensive tube preamps
Or i coud go route of chinese preamps such as fx audio 06 or douk audio P1, what are worth are these?
"Standard" digital playback devices produce a 2 VRMS max. signal. What voltage is needed to drive the power amplification stuff to full O/P? If, as is often the case, the drive needed is less than 2 VRMS, no line stage gain, whatsoever, is in order.
Getting the gain structure squared away, before recommendations are made, is in order.
What voltage gain does your amplifier have? Electrically, you may only need 0dB gain,
and if so either a unity gain buffer, or just a 10k volume control would be fine.
Bottlehead Moreplay 6V6 preamp kit. Fun to build, almost moron proof assembly instructions and best of all sounds fantastic!
I second this.
Thanks for option,
I found also Elekit tu8500 at similar price
I tried the douk audio P1 and fx audio
Douk audio P1 is crap to listen to, it sounds a little unphase plus some hiss sound is introduce
Fx audio is kind of a surprise, essentially for the price
Here a link ok a kit developped by me
Kit Preamplificatore Linea Junior Audio Review nr.407 - 412
published on Audioreview in Italy.
Walter
Walter
Your kit looks really well design, i put it on list
If i understand correctly, there's still to add an enclosure, valves, scews, cables, rca connectors , and what else?
Yes, the accessories must be included.
The Audioelettronica ( my friend, it is helping me on kits) can supply everything.
Also the tubes selected.
Walter
Walter
- Tubes / Valves
- DIY tube preamp kit
