DIY tube preamp kit
Hi all
Could someone point me to a qualitative tube preamp kit at a good price?
I would be using it in front a hypex amps
I just need one IN to connect a dac
In finish products, i have only seen some expensive tube preamps
Or i coud go route of chinese preamps such as fx audio 06 or douk audio P1, what are worth are these?
"Standard" digital playback devices produce a 2 VRMS max. signal. What voltage is needed to drive the power amplification stuff to full O/P? If, as is often the case, the drive needed is less than 2 VRMS, no line stage gain, whatsoever, is in order.
Getting the gain structure squared away, before recommendations are made, is in order.
Thanks for option,
I found also Elekit tu8500 at similar price
I tried the douk audio P1 and fx audio
Douk audio P1 is crap to listen to, it sounds a little unphase plus some hiss sound is introduce
Fx audio is kind of a surprise, essentially for the price
