Hi all,
Has anyone out there made a SPDIF output on a CD-46? Inside is the saa7543 wich has an EBU output on pin 2. I asume this is TTL level. Can I simply hook up the regular conversion (driver chip, transformer, impedance adjustment, RCA connector) to this line?
Hope someone can help me out.
Sikke Kooistra
Sikke Kooistra
It was enabled already. I used CD-46 as transport for my non-OS DAC. I just connect pin 2 (it's SAA7345) to my handwound pulse trans 1:1 through 75R in series and feed the signal from secondary to DAC via 75R coaxial.
However, I live in Thailand and didn't sure that my CD-46 is different to your or not. Hope it's the same. Good luck.
