ABJensen said:It is a corrugated planar tweeter.
Corrugated planer?
I have always had my doubts about that, but if you say it works...ehh, could be that the foam at the edges does the trick, right
tinitus said:
Corrugated planer?
I have always had my doubts about that, but if you say it works...ehh, could be that the foam at the edges does the trick, right![]()
It could be
jzagaja said:Båndsei,,
Could you post harmonic distorsion spectra?
No I am sorry. But they sound fine down too 200-250hz with sharp digitalfilter.
planar ribbon movement - YouTube
Ribbon movement![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I is there any other planar tweeter out there, that can match that ?.
Ribbon movement
Hejsa Andre`,
Can you be more specific about ribbon material and corrugation?
I think it`s hard to find very thin alu foil. In my ribbon I use household 11mY.
True without paper, corrugated horrisontal, 18mm x 1800mm. The impedance is a little tricky, so I use 2 ohm in serial, and super amps and filters from Groundsound (Denmark)
Cheers Jan
Cheers Jan
- Planars & Exotics
- Diy ribbon
