DIY Good Class D amplifier
hi acca sorry for disturbing , but please do a pcb using the 14pin ir2110 .
I tried making one with IR2110, not sure if it's good but here it is...
Yes,and fets will be fast too 😉
I'll wait for pics 😉
Use series limiting bulb with power transformer.
I'll probably order some IRFB4227 fets later, for now I'll do my testing with IRFP250N.
Pics to come tomorrow 🙂
Also I intend to power this (after testing with regular transformer of course) from a car SMPS.
Have you measured the efficiency of the amplifier?
p.s. sadly the store I order my components from is doing some kind of maintenance to their warehouse and I won't be able to order some of the component for another week 🙁.
Max output:
P=U^2/R
With +/-90V,RMS voltage will be 64V (idealy)
On real amp,this will cca. 60V (with 90V stable).
60*60=3600
3600/4ohm=900W
3600/8ohm=450W
Feedback isn't problem.
Just set potentiometer to 0V at output (50% duty cycle).Glue pot if wish,to prevent move from vibrations.0V at output will be very stable.
First try with lower voltages.
