Dear Lucifix,
I have an Rockna dvd-rom controller
can a use your Luckit IDE hexcode to control the this board?
Change..
Go there for source code. with remote you need to know your remote ID code before use Remote Function.
http://www.diyaudio.com/forums/show...30529&perpage=25&highlight=cdrom&pagenumber=4
No time for Kit.
Regards.
Pradit
No time for Kit.
Regards.
Pradit
Dear Lucifix or any one else,
I like to use this with the modi (ROCKNA controller card)
- all remote functions (also open and close button)
- standby
- see on the display the title and the artist
if have try both and 16F877A and 18F452 18F452 is mutch
better thanks to Lucifix
We need for school to change the text in to Holland
could you send me the source for both chips
Thanks in advance
- standby
Thanks in advance
I have build the controller with the 89C51 posted by Roly3055
and also the accompaning programmer. the problem is that i don't know which software to use to put the .HEX file into the controller.
Can somebody help me? please.
Diy cd
This is my new diy cd player
Cdrom controller by lucifix
Dac is my project, cs8416 tda1443
[/URL]An externally hosted image should be here but it was not working when we last tested it.
[/IMG] An externally hosted image should be here but it was not working when we last tested it.
[/IMG]Yes, I got it working. The 89C51 is programmed by a friend of mine knows a lot more than i do about it.
But i think i'm gonna also build the Luckit controller, because this one can't do FFWD and REW. and when i push NEXT button two times, the controller crashes
@Pigioa, nice box you got there. Have you got a picture of the controller?
[/URL]
[/IMG]This is my Power CD Player
Message for " Pigoia" :
ho visto che sei di Bologna, io di Ferrara, perche non parlarci in Italiano ?
Comunque questo è il lavoro che ho appena terminato,
se vuoi puoi contattarmi anche tramite email che trovi su: www.afhifi.altervista.org
Per scambio consigli ed opinioni.
Il DAC cho ho utilizzato è il Cirrus CS4344 24bit 192Khz con 105db di dinamica, devo dire suona molto bene.
This is an English speaking forum. If you wish to post in another language, please also include the English translation.
Thank you.
Thank you.
i wanna ask is this controller can slow down the CD-ROM speed .. ???i think CD-Player reading speed are just 4x if i not mistaken
I have small one worries, I have a cd rom ASUS. I have an exit digital output and I shall want to transform it into optic output. I therefore took a Toshiba Toslink TOTX177 (http: // pdf.eicom.ru / datasheets / toshiba_pdfs / totx177 (fr, t) / totx177 (fr, t) .pdf)
I fed it, the connector cable has to light the red (on it a beam by opening the hatch of protect dust) but has do not have sound.
Thank you🙁
Thank you🙁
Would I like Plextor to use a drive px 130a as you/he/she has made SERGE LISSES, does someone know me to say that controller to use and the relative HEX?
Thanks.
Thanks.
I2S out, is this the lowest jitter I can get?
I was able to find and tap into the 3 I2S signals from the controller chip of my CDROM and feeding it to a TwistedPearAudio DAC. Is this the best jitter performance I can get? What else can I do?
http://eshop.diyclub.biz/product_info.php?products_id=436
This controller works perfectly with the PLEXTOR 130A
Serge
Serge
On the Plextor 130A ,i have also changed the Oscillator with a Tentlabs .
The new oscillator have a dedicated 5v .
Serge
Serge
- Digital Source
- DIY CD drive based on a computer CDROM
