@Ray - are your diaphragms also made via manual cutting, or did you etch the traces?
Did the artwork and have had several versions made - various materials - various production techniques - and five different AMT sizes so far...
I will try to get a roll of 9/12 my alu/polyester(mylar), print the pattern with a laserprinter,and etch it.
Aluminium Polyester Laminates | Flexible Films
I have made a new model:
It measures and sound nice :
Bernt.
![URL]](/community/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fimg6.imageshack.us%2Fi%2F300zj.jpg%2F%5D%5BIMGDEAD%5Dhttp%3A%2F%2Fimg6.imageshack.us%2Fimg6%2F5624%2F300zj.jpg%5B%2FIMGDEAD%5D%5B%2FURL%5D&hash=0e939af0535c4ba5bfc6d3e02f28fbf3)
![URL]](/community/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fimg211.imageshack.us%2Fi%2F3pcs90x40x65mmvert1mona.jpg%2F%5D%5BIMGDEAD%5Dhttp%3A%2F%2Fimg211.imageshack.us%2Fimg211%2F6117%2F3pcs90x40x65mmvert1mona.jpg%5B%2FIMGDEAD%5D%5B%2FURL%5D&hash=87b6e6f72282f57fbc6d909441aff2ba)
Bernt.
The frequency response looks great, XO at 400 Hz?
Is this film thermo setting? If not, how do you plan to keep the pleats in shape?I will try to get a roll of 9/12 my alu/polyester(mylar), print the pattern with a laserprinter,and etch it.
I have only used it fullrange at low volumen,but I will try to cross it low.
It is not the glue that keeps the pleats in shape .The mylar keeps the shape due the heating and cooling.
Bernt
Bernt
I think so.
I have used other mylar/polyester/pet/hostaphan films and it was the same.
I have made an enquiri ,but I am not sure they sell small quantity.
Bernt.
Bernt.
Get in touch with Michael at Mike Woodhouse - Free Flight Supplies.
He has:
LIGHTWEIGHT COVERING MATERIALS, MYLAR COVERING MATERIAL/FOIL:
5 micron aluminised, 1/4 mil, 6.8 gms. per sq. metre, 7.5 metres x 315 mm wide, £5.00 plus post
10 micron aluminised, 1/2 mil, 13.6 gms. per sq. metre, 7.5 metres x 315 mm wide, £5.00 plus post
15 micron aluminised, 3/4 mil, 20.4 gms. per sq. metre, 7.5 metres x 315 mm wide, £5.00 plus post
The aluminium is very thin, so I would go for the 15 micron film. But even then you might have to have the aluminium strips in a parallell fashion.
He has:
You could also check this out: Räddningsfilt i aluminiumfolie
It is 18 gr for each square meter.
I have no idea about the resistance nor its thermo setting properties.
Resistance in aluminised mylar is too high.
Measurements dont show the hole truth.
I cant cross my latest model🙁3 pcs. vertical) lower than 1khz.
I have made a "horn" from 80mm foam tube and it still don´t play low freq.
This one is much better:
I do not use enough time to listen to my different models.
But I still like my 2 pcs. vert. model playing in my living room above 1khz. in a 3way system.
Bernt
![URL]](/community/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fimg834.imageshack.us%2Fi%2Famt850022.jpg%2F%5D%5BIMGDEAD%5Dhttp%3A%2F%2Fimg834.imageshack.us%2Fimg834%2F1986%2Famt850022.jpg%5B%2FIMGDEAD%5D%5B%2FURL%5D&hash=8912f3c9028d26e62f059153124b4c0a)
Bernt
Yes, if all the strips are in series. But if you have several connections you can lower the resistance by connecting them in parallell.
Hello, took months reading and trying to understand, I'm so not knowing english, I hope the google translator reflect what I will describe;? Graphene ò if made would improve the molybdenite is invention? I say that already manufacturing capacitors reference purposes and new batteries with graphene and apparently dramatic improvement is apparently graphene is diamagnetic and my meager apparently can increase the speed of the membranes reducing mass and weight, what are you thoughts about this idea ?
Greetings to all.
Greetings to all.
I use only copper and not aluminum in my diaphragms...
Aluminum are too much affected by the magnetic field...
Hi RayCtech
I hope you will soon let us see some of your babies !...
What are the frequency range of some of them ?
My Best,
My Best,
Hello Bernt,
Perhaps this is another easier and probably lighter way to design an AMT diaphragm... These guys are using Graphene as conductors. This will be the thinner way to trace conductors whatever the design !
Here you have a few links to this method...
http://arxiv.org/pdf/1303.2391v1.pdf
Robert Murray-Smith - YouTube
https://www.smashwords.com/books/view/304668
My Best,
I have seen some of theese videoes ,but how do we handle the graphene after fabrication .Is it liquid or powder?
Bernt
It seems it's a sheet of material made of a simple layer (this is why it's so light...). Here you have more info and perhaps... a sample available !
Graphene Industries -> What is graphene?
It will be some time before we will be able to get graphene sheets of significant size, I'm afraid.
I was reading one of the Beyma research papers about the TPL-150, once again. It seems that they use 12 um Kapton with side-by-side 6 um copper traces. Experimenting with my 24 um Kapton + adhesive, I've found that it does thermoset fairly well, but the silicone glue is tough to cleanly dissolve (with white spirits) without disturbing the Al traces. I have to mechanically pick at it too much. It looks like the 3m 74 tape glue is dissolved more easily.
I think that Beyma's laminate is adhesiveless. I've seen 12 um + Cu Kapton laminate advertised by several producers but can't see where it can be bought in small enough quantities for our purposes.
Thanks for the link solhaga. The spirits that I tried definitely dissolved the glue but not as quickly as I would like. Can you try the white benzene on your kapton and let me know how quickly the glue comes off vs the rubber adhesive on the polyester tape?
I won't buy anything extra until I've moved back to Australia in 3 weeks time. The waiting is annoying, but at least I get to play around here and there and watch your progress.
As far as etching goes, I'm curious to try a sort of stamp for shielding the traces. Cable ties have the right dimensions. With something slightly soft under the tape+Al I think that you could etch fairly sharp lines.
I have just recived a sample of 12my alu on 12my mylar. athe alu is not coated on one side
and can be etched.
I have tried to print with a laserprinter:
alu/paper is taped to a sheat of foto paper.I did not clean the alu before printing.The "ink" pattern can easy be damaged.
Bernt
and can be etched.
![URL]](/community/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fimg546.imageshack.us%2Fi%2Falumylar001.jpg%2F%5D%5BIMGDEAD%5Dhttp%3A%2F%2Fimg546.imageshack.us%2Fimg546%2F1320%2Falumylar001.jpg%5B%2FIMGDEAD%5D%5B%2FURL%5D&hash=006f8bbcd0f6ef2fc4c7c810a8ab1815)
Bernt
- Planars & Exotics
- Diy AMT
