DIY Aluminum Case
It is wonderful when folks without a clue offer advice.
2024T3 is the old aircraft standard for aluminum. Today it is used mostly for keys. It will polish up quite nicely.
3003H14 is crap. It is the cheapest sheet aluminum and is usually sold in rolls. Useful for flashing and decorative uses. The lowest strength on the list.
5052H32 is the standard for sheet metal use. It forms well but does form small cracks on tight bends. it is the material of choice for decent quality sheet metal.
6061T6 is the work horse of aluminum alloys. It welds well is decent at machining, but a bit gummy, so use a lubricant such as Tap-free for aluminum to keep it from sticking to your tool bits and slowing things up.
7075T6 is the stuff they really build airplane parts out of. It is the strongest and most expensive. It with a bit of effort will take a shine and look like chrome.
So use either 5052 or 6061.
Anodizing is a nice way to finish aluminum. If you are bolting the pieces you can use a bit of lye in water to remove the anodizing where you want electrical contact.
There are other finishing processes that leave a conductive surface, but they are not very common these days and a bit expensive.
The easiest way is to use an aluminum top plate and wood sides.
RFI is a problem with bipolar junction transistors, not so much tubes or FETs.
For a 19" panel 1/8" is the minimum thickness for looks 3/16" or 1/4" is better. 1/16 or .062 is fine for small chassis, but for larger ones or to support a heavy transformer go for .080." or there abouts.
Steel is a bad idea. You can actually measure the distortion introduced into an audio signal line when it is routed close to a steel chassis.
ES
Thank you very much. very informative. Hmm my transformers probably >10 lbs so maybe I should go with like 1/8"..
FWIW I have been making my amp chassis since forever (1969).
Always aluminum, hate iron for all the extra work it needs, including sanding/filing rough edges and burrs, anti-oxidation treatment , etc.
In the beginning, I had flat sheet cut and bent at some fabricator's, everything else was drills, Greenlee punches and filing.
I chemically treated surface to get good paint adhesion, and started silkscreening.
Later I bought punchers and dies, which allow holes of any shape (rectangular rocker switches, slots for slide pots, etc.) plus cutting perfect, almost burr less holes.
Even later, bought my own shear and folder to be able to work at a Pro level, at home, and finally got an Aluminum processor to make custom sheets for me, in a size where I have no waste and in the metal hardness I need.
Some examples:
1) a 1972 200W Power Amp (still working weekly ); vendor cut and bent 2mm aluminum, all round (drill) holes, printed paper panel behing 2mm acrylic:
2) home cutting custom 43cm x 1 m x 1.5mm aluminum sheet, with an old shear bought as scrap:
3) bending aluminum , press folder also bought as scrap but added custom made "V" blocks, allow sharp or rounded bending:
4) Full homemade rack cabinet (meaning I started with a flat sheet of metal, not just drilled a pre-made cabinet):
In Stadium use, among some distinguished friends (the top siver one is also mine) :
When I say Stadium, I refer to this:
5) silkscreening panels:
6) some end product panels and chassis:
As you can see, aluminum is a *very* flexible material, and allows Pro results with inexpensive tools.
Scrap yard
I don't understand where he is finding all the aluminum pieces
Hey every town in america has a scrap metal place. Find it. You'd find they sell metal by weight. I pay 1.75 a lb for aluminum @ a place called Foils (yea I know they sell only tin foil is the joke) in harrisburg NC. Alcoa and a 100 others are in every city in america.
You may have to recognize and buy, cos usually they dont have it rated properly. But 6061 and 2024 dominate the aluminum market. You like diamond plate in your amp = easy easy - its usually 6061 and shiny to start with and near freaking indestructible.
Feet - lots of machinery and tool stores have feet in their catalogs. I paid $5 for a baggie full - like 20+.
Cool.
Srinath.
Cool.
Srinath.
I'm in Canada, the only scrap place we have is the government run dump. I know there is electronic disposal there but I don't know if they let you take anything. I will check today.
That silverStone case is $$$$$ ....
Seriously - get a cassette deck from the 80's 90's. One of em black metal case jobs, not the pseudo silver plastic junk. Gut it. Stuff the inside with your amp. As a bonus you have a 9-15v trafo you can wire up to some unholy tube pre ... and slap on a face plate.
Or VCR case ... or any other un functional amp/receiver/cd player etc. Would look like it came from the factory ... cos it did.
Cool.
Srinath.
Loved Speedy Metals, a treasure cove.
They have *everything*.
Par Metal is impressive ... but their prices are impossible.
Almost U$450 for a custom punched and silkscreened 2U Rack cabinet 😱
Nothing, of course, for their "star" customers (Boeing/IBM/Lockheed/etc.) .... but for the average hobbyist it's murder.
No offense, but why waste the time? Just buy a broken Amp off ebay with nice sinks...like my latest - a Hafler Pro2400 - perfect chassis for an F5 for $100 shipped, and I have parts left over like a 48V 0- 48V tranny, caps, resistors, etc...
I will post a pic later.
I live in Canada so shipping is more expensive. Also, the sheet metal is only 40 bucks so it would be way cheaper. I mean.. I can buy all custom cut aluminum plate/sheets that would make the perfect size chassis for like 80 bucks.. why would I spend that much on a broken amp?
well, I went to the 3 scrap metal/electronics places in my area today and none of them sell their stuff...
Canada is one of those countries I've lived in where nothing seems to make sense.
I guess this is one of those.
In my town scrappers cant wait to get their crap out to resale @ retail scrap metal prices instead of cart it to the smelter by the trailer load and get less $$$ ... I buy scrap from them, like wires and transformers out of microwaves etc etc I pay between 50c and 80c a lb depending on what it is. Aluminum is $1.75 a lb, I bought a 4lb 1/8th sheet of 2024. Looks beautiful, cost me $8 or so.
@ smelter they make less than 50 /lb. Anyone who discourages counter sales and only trucks them out is a moron IMHO.
In toronto I've had so much trouble getting parking for my motorcycle. Car lots wanted waaaaaaaay more for parking a motorcycle in a wasted corner spot WTF, that spot sitting there with no $$ comming in - I'll give you $25 a month, nothing you have to do really except not tow the thing if its there. They said no. WTF.
Others didn't want to park a motorcycle at all because there was a sign on the gate arm that said no pedestrians, bicycles, motorbikes, and showed the gate hitting a guy on the back. WTF ...
I love timothy's coffee though, so I guess every place has its advantages.
Oooo dude - take a bunch of wrenches, cutters and pliers and what not with you and go down to your nearest stop sign ... that is decent grade aluminum. A bit thin though.
Seriously man, a VCR is $5 to 10, an old boat anchor like a hitachi or nec from 1985. Craigslist for it.
Cool.
Srinath.
