• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Discrete OPAMP
Helo!
I will reply every email,
It seem I have not received your email.
When I received your email, my mailbox will send a reply email automatic, and I will send another reply in 24 hours.
About SUN(version 2),We thought about some customers feedbacks , then we have in allusion to adjust the circuits and parts , improve and made OPA-SUN (version 2), OPA-SUN (v2) had more humanity than original , but keep energetic, huge dynamics and good impulse response.
Moon:This discrete opamp uses dual differential gain stage and single ended output stage circuit design , we try and listen long term . The OPA-Moon sound characteristics is had a bit tubelike taste (vacuum valve) , soft and thick .
-3dB BW is around 8Mhz witout c, and *worse* with cascoding (5Mhz)
3rd and higher order harmonics rise at an order of magnitude, 2nd is the same (and dominating).
all simulated.
oops..
but this one is an order of magnitude *better* EDIT: only with high freq (20k), 20Hz is still better without cascode!
Just an simulation trick without any connection to the real world?
Rüdiger
