Discrete cfp (op-)amp
If this circuit would work, which is a spin off of a topology of Tietze/Schenk, we had a balanced-SuSy-current-feedback-input stage for MC (phono) with THD to die for.
But I fear the DC-biasing won't be close to the simulation nor stiff enough in reality. Bandwith (-3dB point) sims 1.2MHz, gain is 41 dB
In sim, there is virtually *no* current or voltage through/over V3 (the MC-cart).
Rüdiger
Disabled Account
Joined 2006
Hi nelsonvandal
The best is to save them all together in a zip file and then post them here. After you have created zipfile with a name, to post it you just attach the file with your reply. Youll see this option below the *your reply* and *options*.Just click browse and then point it to zipfile you have, when attached just reply as normal msg.
Hope this helps
Alex
