I have between my DAC and amp relay attenuator + BUF, they do the match of impedance well. So, in case if I use DSD drive it will work in terms of impedance match.
My DAC gives out 3V, but for another source I will have to think about preamp probably.
Anyway - I am waiting for your final result and prices)
Possibly to do a tweak to get 3V output, so preamp not necessary. More details later ...
Ciao Acko,
I am following this thread with great interest also because I know your high level design...
You are planning to propose an already builded and tested board or there is the chance to have the pcb only?
Best Regards,
Enrico
Hi Enrico, this will fully assembled and tested modules. No bare boards as there is a fair amount of complexity. Basically for those who want to setup quickly and listen.
linux BBB integrated + FPGA (pcmtoDSD)+DSD drive instead of amanero also would be interesting.
DAC has 2 I2S ports that can connect/select to any of these:
Actually, not dependent on any particular I2S source.
Digital inputs are compatible with popular sources like:
Amanero, WaveIO, JLSounds(OEM type), BeagleBone and SDTrans384
Hi Acko,
nice project! If I get it right the only DAC part will be the filter. Will it be fixed? Will you make VHDL/Verilog code available? Any guess what the price will be? $100? $500? $1000?
The DAC is more than a filter and characteristics are not fixed. User can select some filter options to suit, DAC also autotunes others for best fit.
Made up of modules but I am initially offering a complete system on a board for those who would like to hook up and listen right away - then add other options, tweaks ->box up and deploy. Also easier to verify operation, performance and support of a know good reference. DSP/FPGA codes will not be made available. Individual modules may be later for those who prefer to build up on their own.
Prices not available at this stage. I am in the process of creating the BOM, hopefully won't be too long.
Sounds great! Looking forward to first results!
This might be of interest to some;
http://www.diyaudio.com/forums/twisted-pear/258254-support-botic-linux-driver-172.html#post4751947
The PCM/DSD outputs from the Beaglebone Black are passed to an Acko SO3 Isolator/Reclocker board, thence to the DAC, in this case a Buffalo IIIse.
The only downside is that DSD256 seems a little marginal with the Linux build I've used but as its a standard 'off the shelf' linux image that might be addressed with some tweaking?
Ray
Ray
Ray
Thank Ray for your contribution!
Hi Ray,
Thanks for your efforts!
Have you tried playing DSD256 music files directly from the SDCard of BBB?
Also from network play if increasing the buffer size helps?
Hi Acko, some progress made, see my updates on the Botic thread.
Ray
What news Acko?
Any sort of product description available yet?
Cheers
Ray
Hi Ray,
As explained before, I am aiming for a "finished" product of a complete DAC system on a board this time round so that performance can be fully evaluated. There are quite a lot of interactions. I am also catering for those who want to hook up and listen right away.
All being well, more information on the individual modules (OEM/DIY) will be released.
Some good progress on the BBB/Botic front;
http://www.diyaudio.com/forums/twisted-pear/258254-support-botic-linux-driver-177.html#post4768839
Bottom line is that my BBB/Botic/NAA combo has been working perfectly at DSD256/PCM192 and almost flawlessly at DSD512/PCM384.
Ray
Ray
Ray
Hi Ray,
9018 chip may not be able to go beyond DSD256?
Hi Ray,
Hi Acko.
It looks as though DSD512 does work;
http://www.diyaudio.com/forums/twisted-pear/258254-support-botic-linux-driver-178.html#post4771009
Ray
Hi Acko.
Ray
Thanks Ray, I am a little circumspect when it comes to pushing things beyond the specified limits and expect desirable results but anyway hope you and others can pursue further and achieve success!
Ray,
I have seen some of your posts from the other side- very interesting efforts!
FYI, your present S03 unit can reclock up to DSD1024. I don't think there is any chip based DAC that can handle this as yet? But your NoDAC with simple filter has no upper limit, theorectically. So I would suggest you disengage your S03 from your DAC and feed it to your NoDAC and see. Obviously you would want to spin the Fs higher to make it easy for your LPF.
Hi Ray,
I did some tests with my AKD12P Sabre DAC last night and was able to push it to DSD512 without any problems. Source 44.1/48k HQPlayer up sampled and NAA drive to BBB/S03 using your Image. Excellent sound with no noise at all times, even when switching Fs, start/stop!
- Group Buys
- Direct Drive DSD
