Dir1703-pcm1710u-??
627 died or 637 died !?!?!? I have experience with both and I never had one dead. I gave a reaction because the 637 ( stable with gain greater than 5, see datasheet ) is practically only useable in phono or poweramplifiers but not in filters...
Jean-Paul
last schematic
opa637 did give oscillations in the filter although not always audible.
I changed it to OPA627 (thanks for mentioning jean-paul)
and signal is clear on the oscilloscope.
Changed the crystal to 16.9344MHz (2dB more Dynamic range).
Dir1703 doesn't need reset always.
I think it is plug'n'play if there is spdif input
when you power on the circuit.
Attached is the last schematic.
makisb
