DIR1703 multiple unlock frequencies
Hi, I know there is a few DIR1703 threads out there - but I wonder if any body has this issue. I had a problem with the DIR1703 unlock pin staying high, no matter what mode (crystal or pll) the chip was in, or what option was selected. So to test this I fed a square wave to the chip. I then varied the frequency to see at what frequencies I might get low on the unlock pin.
The results:
600KHz
1MHz
2.6MHz
2.7MHz
3.9MHz
4MHz
Checking this website http://www.epanorama.net/documents/audio/spdif.html it says "Signal bitrate is 2.8Mhz (Fs=44.1kHz), 2Mhz (Fs=32kHz) and 3.1Mhz (Fs=48kHz)". Now to check out what frequency was coming out of my soundcard (Soundblaster live digital Entertainment 5.1). To get the true frequency of a S/PDIF signal I worked out the frequency over a number of periods. The result 2.2MHz. I am still not getting any data out. Have I got a correct S/PDIF signal?
The first picture shows what the S/PDIF looks like with 75 ohm termination. The second picture shows the signal after the inverters before the chip. I have bypassed the crystal, sending a signal from a waveform generator instead(for testing purposes). Although the circuit shows 74hc04 chip, I could not get this working. So now I am using GD4069UB. It gives a clean signal (as shown). I have not used the 74HCU04 as stated in other threads because the freight is way to high (only cents for a chip but about US$20 for freight). I may have to bite the bullet and buy it. Has anyone got the circuit working with a chip that is not the 74HCU04?
Also anyone annoyed that the DIR1703 is now discontinued? I have checked the TI site and can not find a replacement. They have discontinued this product due to problem locking on to the signal after the sampling rate changes. Could this be related to my problem? I would be interested to hear from people that have had this chip working, to see what sorts of problems they had.
Thanks.
The image did not show - ill try again.
Your results are invalid for two reasons.
SPDIF is biphase-mark encoded and the code-violations that create the preambles that define the start of channels A and B and the Channel status block are missing.
I suggest you get a copy of either IEC60958 or AES3. These douments define the SPDIF/AES_EBU standard.
I agree that what he's doing is unusual, but I assume that with a square wave input he should be able to get LOCK asserted but with NOTAUDIO also asserted.
