Diode physics
A capacitor won't filter much when you drive it from a near-zero impedance and micropower voltage references are generally quite noisy, so it's probably better to put an RC noise filter in between the reference and the op-amp - but then again, Jan didn't specify noise requirements.
If noise and inductance don't matter you could use a TS4061 or similar shunt regulator IC.
OK OK< stop twisting my arm ;-)
Recap: my query originated from trying to use a 2-diode drop 'thingy' as cathode resistor in a small signal tube circuit (no I won't show the circuit).
Then I looked at the diode-drop variation with current, and I thought: which type of diode would have the lowest voltage drop variation, ie. the steepest V/I slope, hence the 'physics' question.
And look where we ended up! But, as often here, I learned several things on the way, for which I thank all of you.
PS Yes there are 1.2V shunt references, but they have noise and cost upward from $6. I do have a Dutch reputation of frugality to uphold.
Jan
Sure you can beat any tube circuit to death using a few transistors.
What would be the use of using tubes then ?
I understand why you do not want to show the circuit.
Georg Neumann invented the NiCd cell in order to replace a cathode resistor.
My educated guess would be around 70 nV/sqrt(Hz), assuming that it uses a simple bandgap with 8:1 transistor and 1:1 current scaling (which is suboptimal, but only slightly) and that most of the minimum cathode current for regulation flows through the bandgap reference. But that's only a guess.
