Digital Designs Z2HV
I’m working or this amp lil by lil when I have time .
Im ready to install the outputs in the amp . This amp uses the 4 driver ic board (4xIR21844s)
I have enough outputs for 2 banks but not enough for all 4 banks .
My question is if I use the outputs I have for 2 banks and order more for the other 2 banks would that cause issues since all 4 banks won’t have matching date codes or should I order all new outputs for the 4 banks ?
I have 2 high output alternators rated at 390 amps . These are stand alone alternators the factory alt is still in the truck also I’m using the factory alternator to control the factory electronics and the 2 390 amp alternators for the charging system for the audio . I also have a 120ah c max battery they said is good for amps up to 22,000 watts
Since this amp has 2 separate boards a power supply board and output board I’m going to test the power supply board after the repairs .
I will be using this amp at 16 volts .
Wondering what’s the best way to check the drive signals ect with a variable power supply so I start looking at drive signals at 12 volts and increase it up to 16 while looking at the drive or what voltage should I start at
Something is right with the drive to 1 of the banks of fets .
Pic 1 is 1 bank of fets pic 2 is another bank .
Pic 2 the fets get hot after about a min
scope set to 5us .5 volts div
