Hi!
Inductance of MM cartridges plays a role in their sound signature. Obviously i'm not attesting anything new or revelatory.
Not sure i understand exactly how it affects performance but was pretty surprised to find out how much different the same stylus sounded on cartridge bodies with different inductance (otherwise identical).
The two cartridge bodies belong to the same family, with interchangeable styli.
One is a Shure M55E (pre-2000, Mexico made) and the other is a Shure M44-7 (post-2000, Mexico made). Used the same stylus on both for evaluation (N55E Improved, original stylus). Cartridge headshell used, turntable, VTF and all the other variables were kept identical.
According to my LCR meter, the cartridges showed the following values:
Shure M44-7
Resistance: R 681Ω, L 680Ω
Inductance: R 568mH, L 606mH
Shure M55E
Resistance: R 690Ω, L 690Ω
Inductance: R 759mH, L 721mH
Didn't expect them to sound as different as they did, given the above values.
Resistance is almost identical, being only 9Ω and 10Ω higher on M55E, for each channel respectively.
Differences in inductance are more pronounced though. 191mH and 115mH higher on the M55E, for each channel respectively.
Links to audio recordings of both cartridge bodies with same stylus:
Shure M44-7
Shure M55E
When i listen the two recordings, the one with the higher inductance (M55E) sounds substantially wider in terms of channel separation and with less pronounced high octaves. The other body (M44-7), has an overall brighter rendition with a somewhat collapsed soundstage in comparison.
So, is it down to the difference in inductance?
Maybe.
My only reservation is that there might be other factors affecting the result, which i'm unable to identify/measure.
Regards, Nikos.
Shure M44-7
Shure M55E
Shure M44-7
Shure M55E
Maybe.
Regards, Nikos.
You probably know more about the electrical characteristics of MM cartridges than I, but I'll start the ball rolling in your thread!
The MM cartridge is essentially a simple resistor, inductor, capacitor (RLC) filter which has a resonant frequency.
As the value of inductance increases, the resonant frequency falls, which would account for why the M55E has less pronounced higher octaves.
With a higher inductance, the electrical resonance will occur at a lower frequency and the response will fall off sharply above that frequency.
I read that "Using an inductance meter to measure the cartridge's inductance won't work! The DC resistance is high compared to the inductive reactance, so the meter will lie, and indicate that inductance is much higher than it really is."
https://sound-au.com/articles/cartr...ber,types have an inductance of 400mH or more.
I used to have a Shure M44/7. Good little cheapie. About 2g tracking weight and tough as old boots. The M55E must be a better elliptical stylus. Possibly tracks lighter.
It's tonally down to the interaction between cartridge inductance,usually 500mH, cable and preamp input capacitance (100-400pF) and the resistive preamp load which is usually 47k.
https://sound-au.com/articles/cartridge-loading.html
My experience is the lower the capacitance, the better it sounds. This, I think, is because the electrical resonance affects the mechanical properties of the stylus in the groove at the very highest frequencies.
A sort of mistracking.
If you add a couple of 1k metal oxide resistors in the cartridge headshell on the hot output's solder tags the sound is transformed much smoother, at the loss of a bit of HF and additional noise.
People argue about this endlessly, but I did a lot of experiments on this. My conclusion is some low inductance MI types sound much better. Grado make cartridges (say 100mH) like that. But need a heavy toenarm.
Thanks for replies.
So if you wants to emulate the effects of a higher inductance, would it be possible to add a small coil in series with the hot terminals?
Or maybe by using a 'heavier' load?
For example 22kΩ instead the standard 47kΩ.
I'll hand over to the cartridge experts, but remember you can experiment with the capacitance of the cable between cartridge and preamp.
That would just be to add leakage inductance, not generator inductance, which would raise the level. All you will get is more HF loss.would it be possible to add a small coil in series with the hot terminals?
If you load the cartridge with 33kΩ, would the effect be similar. Would it lower the resonance frequency of the cartridge?
- Analogue Source
- Difference in Inductance - How does it affect MM Cartridge sound?
