Difference between 3 pin and 2 pin capacitor
You will most likley find the third pin is left unconnected, they are their to stop such a big cap from pulling out one of the other pins during times of mechanical stress, shipping etc.
Hopefully the cap is marked, I had some ROE caps with 4 legs, 2 were dummy pins but the Cap had no marking as to what were what, most annoying 🙁
<font size="+0" color="#008080" face="timmons">Regards
James</font>
magnus,
Another possibility, although I can't tell from the picture, is that the can actually contains two capacitors. I have a number of caps on hand that have a common ground and two or more pins for seperate caps in the same casing. It's not as common as it used to be, but there are still some to be found.
Grey
I've juste got two caps out of an older amp, and they to have 3 pins! It seems that ground is common, and it charges on both the other pins, but there isn't really a way of checking that it charges correctly, is there??
Isn't marked in any special way, just says 44V 6800 microF
/Chris
Alright Taz! Where are the pictures of the Zen V4 on your website? Just to add to this thread I have found some 3 pin "computer grade" caps. The third pin is definately just for mechanical integrity. It should have no electrical connection. If it were a two section cap it would be MUCH larger.
G
All,
Although the capacitor in the link undoubtly has an extra dummy pin, three pin caps exist for supression circuits. The usual "delta" configuration consists of two class-Y caps between the hot terminals and earth with a third class-X cap connected between the two hot terminals.
Here's a datasheet with a connection diagram:
http://www.evox-rifa.com/cap_catalog/deltaemi/pzb300.pdf
Nice one,
David
Third pin
I got a few of those caps from Brigar. The third pin is only for mounting. It makes the cap stable (eliminates wiggling) as well as acting as polarizing pin as Fred said.
For my case, I mounted them upside-down with hot melt glue, and ground off the third pin to avoid shorting anything with my connections.
