Yeh, I say take out those Telefunkens and keep them somewhere safe for a later amp or eBay, and fill that power supply up with some SOVTEKs or whatever. I highly recommen keeping that power supply intact and fixing it up a little - it will be very useful for you on the bench. I would replace the electrolytic capacitors if i were you.I have a solid state 0-450 (actually goes to 500) volt @ 150 (actually goes up to 200+ before current limit) power supply with 0-100 volt negative bias (regulated at a couple Ma) that shares a common ground with the HV, a 6 volt, 3 amp winding (floats), a 6-0-6 volt winding at 3 amps (floats), a built in 2 amp variac, and a 0-40 volt, 0-1 amp (floating) power supply for solid state work. The 0-40 volt has an adjustable current limiter. The 0-40 and HV supplies have vernier controlls, and everything is circuit breakered. I find a power supply like this to be VERY useful - I use mine every day.
