TheSeekerr said:Well, if you want 2 boards, I'm up to 7 boards total, and 2 boards would cost you $22 each including shipping. If you want 5 boards, I'd be up to 10 boards total, and they'd cost you $14 each including shipping. If the total order reaches 20 boards, those 5 boards now only cost $10 per board, including shipping.
All numbers are approximate, but pretty close.
So, yeah, not so good value at the moment, but the price goes down fast if you want 5>15 boards, or if more people are interested.
(Shipping would be via prepaid airmail satchels, costing $15, and capable of shipping about 15 or 20 boards, depending on what they weigh)
What would the cost be for say 50 boards? Just want to compare to the prices I will get for the group buy. Is it complete with soldermask, silkscreen and panelization?
TSeekerr,
Thanks for listing the prices, but it's more than I'm willing to invest right now. I'll just hold off until a larger group buy is started. I guess I'll just have to wait a little while longer.
Hi MrMajestic - I haven't had a quote done for the initial shipping (from China) for such a large amount of boards. If you want to find out, just email sales@ourpcb.com - they've been very helpful with all my questions so far (about an unrelated order) and they'll gladly give quotes for all number of things.
Their standard service includes soldermask and silkscreen. I haven't asked about panelisation, but their prices per board seem very low (the above prices, for instance, were based on a quote I had done for 6x4" boards, rather larger than the diamante.)
Hi !
Still finishing the boards, waiting for some parts, they've been ordered and should be delivered maybe before this WE.
Just a question about resistor 21R/2W.
I've got insulated copper wire in 0.5mm.
Does it fit or not ?
Thanks 😉
Thanks 😉
korben69 said:Hi !
Thanks 😉
Thats the gauge I used, fits nicely.
korben69 said:Express Support !!! 😀
15 or 20 turns ?
I did 20 turns on mine.
15 or 20 turns ?
It is not critical you can even do more than 20 if you like.
korben69 said:Doesn't seem to be soldered on the resistor... I'm right ?
You should burn or scrape off the enamel from the wire on both ends, then solder the ends to the resistor leads.
Cheers!
Russ
Cheers!
Russ
Oops, must have missed that part. Thats why its doesnt look soldered on my build, because its not.
I bet it will sound a bit better after you solder the coil. 🙂
It allows a low impedance path for the music, while creating a high impedance for RF.
Right now eveything coming out of your amp has a relatively high output impedance.
Cheers!
Russ
Cheers!
Russ
And it sounds fantastic even without it. Have to get cracking on the coil 🙂 Thanks Russ.
TheSeekerr said:Any word on getting a few more of these boards out into the wild?
Well, Im waiting for korben69 and the other builder to finish up their boards first. After that, the group buy can commence I hope.
Some news, both boards are stuffed and soldered.
C5 and C6 are empty right now but I've got the parts.
Some wiring stuff to perform, I've found a 10K Alps pot.
I'm in lack of +15/-15 PSU, I've got to build one ordered to Bob ELLIS.
korben69 said:Some news, both boards are stuffed and soldered.
Great, keep it up 🙂
korben69 said:It's Alive ! 😀
More informations tomorrow
Sweet, cant wait to hear what you think 🙂
- Diamante -a discrete medium power opamp
