Detecting Voltage Drop
I need to detect when the voltage drops in a battery powered circuit. NOT to a certain voltage, but rather when the voltage quickly sags.
I want/need/require to do this using discrete transistors [NO ICs!] and as cheaply as possible.
I was thinking of a resistor and capacitor [in series] across the power - with a PNP transistor wired;
base to V+ side of the resistor
emitter to resistor/capacitor junction
but no luck...............should I 'tie' the collector to ground via a resistor - say 100K?
And get the signal from the collector that way?
The voltage in the circuit is up to 48V - any risk of blowing the transistor?
Thanks!
Ken
I think what you are looking can do it with a voltage comparator op amp. You set the limit and if the voltage fall below it will set and output. You can use an led to indicate when you have a voltage down. Do a Google "voltage comparator op amp" and you will find a lots of web side explaining it.
Cap size will determine duration of pulse.
Sorry I used so many diodes...some are for protection.
Close?
The easiest, cheapest and most simple solution involves an Op Amp.
An LM358 starts at U$0.22 dropping to U$0.10 bulk.
Care to reconsider?
Please answer:
1) range of voltages to be measured.
2) voltage drop to be detected.
3) knowing the approximate period or duration would help
This detects instantaneous (here meaning all the time) load current, not exactly the same of what you are asking.
Will trigger at a set total current value , catching only relatively gross ones.
Again, not the same as detecting a drop in supply voltage.
Which transistor?😕
So far we have selected no one.:shhh:
diodes 1N4002
transistors MPSA06 and MPSA56
Resistors 100K
Caps: make the one on the right 10 times as large a value as the one on the left
You can also use one less diode...see new jpg
many thanks to all
I get the stupid b*gger of the day award
It does work, as I 1st outlined.................some days, one should NOT do electronics!
The LED limits the voltage across T1 BE, and blocks reverse voltage flow when the voltage drops, keeping the V across the cap.
So when V+ drops, T1 turns on and hence T2 turns on - driving the load. C2 stretches the 'pulse'.
