Deriving I2S from Sony CDP
Re: Re: Deriving I2S from Sony CDP
rfbrw said:
No. You will not get I2S out of this DSP without a considerable amount of glue logic. The CX23034 is strictly a Sony format device and I mean Sony not Sony/BB.
For the input to the CX23034.
Pin5 = LRCK@44.1KHz
Pin6 = WCLK@88.2KHz
Pin7 = Serial Data (Two's Complement MSB first)
Pin8 = BCLK@48Fs (2.116800MHz)
You need the TDA1543A
ray.
I have a player that has CX23034 in front of the DAC and with bypassed CX23034 it still works.
Now I want to use the DAC of that player with CS8412 receiver with or without the CX23034 . Is it possible ?
The DAC uses bitclock, wordclock, data and L/R clock.
Or would it be easier with Yamahe receiver YM3623B ?
Why does the Yamaha use a crystal ? Better ?
Send 32 bit per frame data to a shift register, copy into another register and read out with new clock and 24 bit per frame ?
Isn't that recklocking as side effect ?
Also CS8412 provides only LRCLK or WCLK, not both at the same time.
Modifying a circuit is not an easy task, it requires experience and is usually done by trial and error where parts are substituted in a circuit and listened to. In that way it's really hard to provide any specific recommendation for a given unit, uness one already performed proven mods.
Here's the link the mods I did on my LM37 transport: http://www.diyaudio.com/forums/showthread.php?postid=896134#post896134 , they worked out well and I can surely reccomend those ones. Regarding the Sony transport I would be clueless what to do.
This is mostly a reply to an e-mail enqiery you sent me a while back. I also like that particular Sony transport, but didn't do anything about it yet.
Applies only if it's a normal Sony (In fact, every Sony CDPs I opened) :
CM made a circuit to convert 3 different EIAJ formats to I2S.
http://www.diyaudio.com/forums/showthread.php?threadid=58564
As for SPDIF, in a Sony CDP, it's not on the digital filter, but on the drive controller that you're going to find it. Try to find a DOUT pin on the transport PCB or the chip between the transport and D/F if there's one.
You have a lot of chances to find a DOUT pin on the DAC PCB and transport PCB. There's going to be an MD2 pin also, and you need to pull it high, make sure it's not presently grounded.
I guess i could try.
